Giriş
This guide will allow you to remove the set of three spark plugs in your Citroen C1 | 1.0 gasoline enginge, to clean or replace them.
Cleaning the spark plugs is recommended when a warm start is difficult, or braking appears unstable. A fouled spark plug can result in a weaker spark or even no spark at all.
The lifespan of a sparkplug varies between 30,000 to 60,000 km (18,640 to 37,280 miles), depending on the brand and use of the vehicle.
This guide is equally valuable for Peugeot 107 and Toyota Aygo vehicles, which use the same platform and the same 1.0 VTi gasoline engine, 68hp.
Neye ihtiyacın var
Open the engine hood of your C1, pulling the controller located below and to the left of the steering wheel.
Disconnect the battery.
Identify the air filter box.
Pull back the hooks to detach the air filter box.
Loosen the clamp and move it up to free the sleeve.
Loosen the air intake pipe clamp.
Unscrew the three bolts of the ignition coils with the help of a 10mm 6-point socket.
Remove the three ignition coils by pulling them upwards.
Grab a spark plug wrench (size 16mm)
Insert the wrench into the first spark plug chamber, until you reach the bolt.
Unscrew the first spark plug, then remove it from its chamber.
You can now proceed to clean or replace the spark plugs.
To reinstall the spark plugs, repeat this procedure in reverse.
To reassemble your vehicle, follow the instructions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Annie dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
3 Yorum
Tuto carré net précis ?
Really helpful. Many thanks.
