Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
Remove the cog the rest of the way with your hand. Replace with a new cog.
Bir başkası bu kılavuzu tamamladı.
