Ana içeriğe geç
Replacing Creative Zen X-Fi Battery
Neye ihtiyacın var
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: adım 1, 3 resimden 1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: adım 1, 3 resimden 2. Replacing Creative Zen X-Fi Battery, Detaching Front Case: adım 1, 3 resimden 3.
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: adım 2, 1 resimden 1.
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: adım 3, 1 resimden 1.
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: adım 4, 1 resimden 1.
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: adım 5, 1 resimden 1.
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: adım 6, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: adım 7, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: adım 8, 1 resimden 1.
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: adım 9, 2 resimden 1. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: adım 9, 2 resimden 2.
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Westley Courchene
3.389 İtibar
14 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G1
5 Üyeler
Bir Yorum
very clear pictures!
John - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 6,809
