Ana içeriğe geç
Replacing Creative Zen X-Fi Button Input Chip
Neye ihtiyacın var
  1. Replacing Creative Zen X-Fi Button Input Chip, Detaching Front Case: adım 1, 3 resimden 1. Replacing Creative Zen X-Fi Button Input Chip, Detaching Front Case: adım 1, 3 resimden 2. Replacing Creative Zen X-Fi Button Input Chip, Detaching Front Case: adım 1, 3 resimden 3.
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    FixBot'a Sor
  2. Replacing Creative Zen X-Fi Button Input Chip, Rubber Button Cover: adım 2, 1 resimden 1.
    • The black rubber button pad can be removed by simply picking it up.
    FixBot'a Sor
  3. Replacing Creative Zen X-Fi Button Input Chip, Button Input Chip Part 1: adım 3, 1 resimden 1.
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    FixBot'a Sor
  4. Replacing Creative Zen X-Fi Button Input Chip, Button Input Chip: adım 4, 1 resimden 1.
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    FixBot'a Sor
  5. Replacing Creative Zen X-Fi Button Input Chip, Access Midsection Plate: adım 5, 1 resimden 1.
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    FixBot'a Sor
  6. Replacing Creative Zen X-Fi Button Input Chip, Unscrew below Button Chip: adım 6, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    FixBot'a Sor
  7. Replacing Creative Zen X-Fi Button Input Chip, Unscrew below LCD Screen: adım 7, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    FixBot'a Sor
  8. Replacing Creative Zen X-Fi Button Input Chip, Unsolder the Button Input Chip: adım 8, 1 resimden 1.
    • Locate the soldering joints connecting the button input pad to the motherboard.
    • Hold the wires in place for easier access to the soldering joints.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Westley Courchene
3.410 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 75
Her zaman: 587
