Ana içeriğe geç
Replacing Creative Zen X-Fi Speaker
Neye ihtiyacın var
  1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: adım 1, 3 resimden 1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: adım 1, 3 resimden 2. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: adım 1, 3 resimden 3.
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    FixBot'a Sor
    Yorum Ekle
  2. Replacing Creative Zen X-Fi Speaker, Rubber Button Cover: adım 2, 1 resimden 1.
    • The black rubber button pad can be removed by simply picking it up.
    FixBot'a Sor
    Yorum Ekle
  3. Replacing Creative Zen X-Fi Speaker, Button Input Chip Part 1: adım 3, 1 resimden 1.
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    FixBot'a Sor
    Yorum Ekle
  4. Replacing Creative Zen X-Fi Speaker, Button Input Chip: adım 4, 1 resimden 1.
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    FixBot'a Sor
    Yorum Ekle
  5. Replacing Creative Zen X-Fi Speaker, Access Midsection Plate: adım 5, 1 resimden 1.
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    FixBot'a Sor
    Yorum Ekle
  6. Replacing Creative Zen X-Fi Speaker, Unscrew below Button Chip: adım 6, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    FixBot'a Sor
    Yorum Ekle
  7. Replacing Creative Zen X-Fi Speaker, Unscrew below LCD Screen: adım 7, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  8. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: adım 8, 2 resimden 1. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: adım 8, 2 resimden 2.
    • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
    • Once unscrewed, pick up the case and put it to the side.
    FixBot'a Sor
    Yorum Ekle
  9. Replacing Creative Zen X-Fi Speaker, Removing the Speaker: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Westley Courchene
3.410 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 710
