Ana içeriğe geç
Replacing Creative Zen X-Fi Speaker
Neye ihtiyacın var
  1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: adım 1, 3 resimden 1. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: adım 1, 3 resimden 2. Replacing Creative Zen X-Fi Speaker, Detaching Front Case: adım 1, 3 resimden 3.
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Speaker, Rubber Button Cover: adım 2, 1 resimden 1.
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Speaker, Button Input Chip Part 1: adım 3, 1 resimden 1.
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Speaker, Button Input Chip: adım 4, 1 resimden 1.
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Speaker, Access Midsection Plate: adım 5, 1 resimden 1.
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Speaker, Unscrew below Button Chip: adım 6, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Speaker, Unscrew below LCD Screen: adım 7, 1 resimden 1.
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: adım 8, 2 resimden 1. Replacing Creative Zen X-Fi Speaker, Unscrew Speaker's Cover: adım 8, 2 resimden 2.
    • Use a Phillips Head screwdriver to unscrew the 3/16 inch screw that attaches the speaker's cover the the back case.
    • Once unscrewed, pick up the case and put it to the side.
  9. Replacing Creative Zen X-Fi Speaker, Removing the Speaker: adım 9, 1 resimden 1.
    • With the speaker exposed, use a pair of tweezers to lift the speaker out of the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Westley Courchene
3.362 İtibar
14 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G1
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 293
