Ana içeriğe geç
Replacing IBM ThinkPad 560z Speaker
Neye ihtiyacın var
  1. Replacing IBM ThinkPad 560z Speaker, Battery Removal: adım 1, 1 resimden 1.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Replacing IBM ThinkPad 560z Speaker, Upper Case: adım 2, 1 resimden 1.
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  3. Replacing IBM ThinkPad 560z Speaker: adım 3, 2 resimden 1. Replacing IBM ThinkPad 560z Speaker: adım 3, 2 resimden 2.
    • Open the flap on the left hand side.
  4. Replacing IBM ThinkPad 560z Speaker: adım 4, 2 resimden 1. Replacing IBM ThinkPad 560z Speaker: adım 4, 2 resimden 2.
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  5. Replacing IBM ThinkPad 560z Speaker: adım 5, 2 resimden 1. Replacing IBM ThinkPad 560z Speaker: adım 5, 2 resimden 2.
    • Open the flap on the right side.
  6. Replacing IBM ThinkPad 560z Speaker: adım 6, 1 resimden 1.
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  7. Replacing IBM ThinkPad 560z Speaker: adım 7, 2 resimden 1. Replacing IBM ThinkPad 560z Speaker: adım 7, 2 resimden 2.
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  8. Replacing IBM ThinkPad 560z Speaker: adım 8, 1 resimden 1.
    • Use your fingers or a spudger to detach the connector.
  9. Replacing IBM ThinkPad 560z Speaker: adım 9, 2 resimden 1. Replacing IBM ThinkPad 560z Speaker: adım 9, 2 resimden 2.
    • Carefully lift and remove the keyboard.
  10. Replacing IBM ThinkPad 560z Speaker, Speaker: adım 10, 2 resimden 1. Replacing IBM ThinkPad 560z Speaker, Speaker: adım 10, 2 resimden 2.
    • Slowly and carefully lift the speaker with your fingers.
    • The port that the speaker plugs into can be easily removed from the motherboard if not careful! Unplug the speaker with extreme caution!
  11. Replacing IBM ThinkPad 560z Speaker: adım 11, 2 resimden 1. Replacing IBM ThinkPad 560z Speaker: adım 11, 2 resimden 2.
    • Use your fingers to unplug the wires from the connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Derek Driscoll
119 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G27
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,740
