Ana içeriğe geç
Replacing Jammed Lead in a Mechanical Pencil
Neye ihtiyacın var
  1. Replacing Jammed Lead in a Mechanical Pencil, Lead: adım 1, 2 resimden 1. Replacing Jammed Lead in a Mechanical Pencil, Lead: adım 1, 2 resimden 2.
    • Twist the cone of the mechanical pencil counterclockwise to remove it.
  2. Replacing Jammed Lead in a Mechanical Pencil: adım 2, 2 resimden 1. Replacing Jammed Lead in a Mechanical Pencil: adım 2, 2 resimden 2.
    • Twist and pop out the eraser shaft.
    • It should come out with the long tube.
    • Be cautious as the spring could also come out. Make sure to not misplace it, as it is quite tiny.
  3. Replacing Jammed Lead in a Mechanical Pencil: adım 3, 1 resimden 1.
    • Remove any excess lead from the eraser shaft hole that may be causing the jam.
    • Gently tap it against the table if it doesn't come out.
  4. Replacing Jammed Lead in a Mechanical Pencil: adım 4, 2 resimden 1. Replacing Jammed Lead in a Mechanical Pencil: adım 4, 2 resimden 2.
    • Gently pull out the lead dispenser from the sleeve.
  5. Replacing Jammed Lead in a Mechanical Pencil: adım 5, 3 resimden 1. Replacing Jammed Lead in a Mechanical Pencil: adım 5, 3 resimden 2. Replacing Jammed Lead in a Mechanical Pencil: adım 5, 3 resimden 3.
    • Push the gold cover down from the dispenser to release the jammed lead.
  6. Replacing Jammed Lead in a Mechanical Pencil: adım 6, 1 resimden 1.
    • Insert the eraser shaft into the pencil sleeve and hold it down.
  7. Replacing Jammed Lead in a Mechanical Pencil: adım 7, 2 resimden 1. Replacing Jammed Lead in a Mechanical Pencil: adım 7, 2 resimden 2.
    • Gently insert the lead dispenser into the other side of the pencil sleeve until you hear a "click."
    • Screw the nose cone clockwise to reattach it to the pencil.
  8. Replacing Jammed Lead in a Mechanical Pencil: adım 8, 3 resimden 1. Replacing Jammed Lead in a Mechanical Pencil: adım 8, 3 resimden 2. Replacing Jammed Lead in a Mechanical Pencil: adım 8, 3 resimden 3.
    • Take another lead and gently insert it through the cone of the pencil.
Sonuç
Iqra Inam
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 135
