Ana içeriğe geç
Replacing Motorola V60i Logic Board
Neye ihtiyacın var
  1. Replacing Motorola V60i Logic Board, Battery: adım 1, 2 resimden 1. Replacing Motorola V60i Logic Board, Battery: adım 1, 2 resimden 2.
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Replacing Motorola V60i Logic Board: adım 2, 2 resimden 1. Replacing Motorola V60i Logic Board: adım 2, 2 resimden 2.
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Replacing Motorola V60i Logic Board, Back Plate: adım 3, 1 resimden 1.
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Replacing Motorola V60i Logic Board: adım 4, 2 resimden 1. Replacing Motorola V60i Logic Board: adım 4, 2 resimden 2.
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Replacing Motorola V60i Logic Board: adım 5, 1 resimden 1.
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Replacing Motorola V60i Logic Board, Motherboard: adım 6, 1 resimden 1.
    • Gently lift logic board from back plate.
  7. Replacing Motorola V60i Logic Board: adım 7, 2 resimden 1. Replacing Motorola V60i Logic Board: adım 7, 2 resimden 2.
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Sonuç
Elizabeth OBrien
43 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 üyesi
CPSU-GARNER-S10S30G40
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,167
