Ana içeriğe geç
Replacing Nintendo DS Battery
Neye ihtiyacın var
  1. Replacing Nintendo DS Battery, Battery: adım 1, 3 resimden 1. Replacing Nintendo DS Battery, Battery: adım 1, 3 resimden 2. Replacing Nintendo DS Battery, Battery: adım 1, 3 resimden 3.
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Replacing Nintendo DS Battery: adım 2, 1 resimden 1.
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Replacing Nintendo DS Battery: adım 3, 1 resimden 1.
    • Remove the battery from the Nintendo DS.
Sonuç
Make sure to press the power button on the Nintendo DS when finished to confirm the battery is working.
11 farklı kişi bu kılavuzu tamamladı.
dnguye26
740 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G3
4 Üyeler
31 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 99
Son 30 gün: 445
Her zaman: 33,794
