Ana içeriğe geç
Replacing Nokia Classic 2600c-2b Faceplate
Neye ihtiyacın var
  1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: adım 1, 2 resimden 1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: adım 1, 2 resimden 2.
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Replacing Nokia Classic 2600c-2b Faceplate: adım 2, 1 resimden 1.
    • Remove the back cover to expose the battery.
  3. Replacing Nokia Classic 2600c-2b Faceplate: adım 3, 2 resimden 1. Replacing Nokia Classic 2600c-2b Faceplate: adım 3, 2 resimden 2.
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Replacing Nokia Classic 2600c-2b Faceplate: adım 4, 2 resimden 1. Replacing Nokia Classic 2600c-2b Faceplate: adım 4, 2 resimden 2.
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Replacing Nokia Classic 2600c-2b Faceplate: adım 5, 1 resimden 1.
    • Remove the faceplate with the number pad attached.
  6. Replacing Nokia Classic 2600c-2b Faceplate: adım 6, 1 resimden 1.
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Apply new faceplate.
    • Follow the instructions in reverse order to reassemble the phone.
Sonuç
Ian VanZandt
654 İtibar
5 adet Kılavuz yazıldı
Ekip
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 üyesi
JMU-KLEIN-S12S3G1
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 397
