Ana içeriğe geç
Replacing Nokia X3-02 LCD
Neye ihtiyacın var
  1. Replacing Nokia X3-02 LCD, LCD: adım 1, 3 resimden 1. Replacing Nokia X3-02 LCD, LCD: adım 1, 3 resimden 2. Replacing Nokia X3-02 LCD, LCD: adım 1, 3 resimden 3.
    • Before disassembling your phone, be sure it is powered off.
    • To remove the back cover press the two "buttons".
    • Remove the battery.
  2. Replacing Nokia X3-02 LCD: adım 2, 2 resimden 1. Replacing Nokia X3-02 LCD: adım 2, 2 resimden 2.
    • Remove the three 3mm black screws on the top of the phone.
    • Remove the two 5mm screws.
    • Loosen these two screws at the bottom of the phone.
    • Probably these screws will not come out from their home, no matter. It is only important to unscrew them completely.
  3. Replacing Nokia X3-02 LCD: adım 3, 3 resimden 1. Replacing Nokia X3-02 LCD: adım 3, 3 resimden 2. Replacing Nokia X3-02 LCD: adım 3, 3 resimden 3.
    • With a plastic opening tool remove the little piece of plastic in the bottom of of the phone.
    • The two corners marked are VERY SLENDER, when removing the plastic be very careful. Otherwise you will break them.
    • To remove the logic board assembly push from the rear of the phone.
  4. Replacing Nokia X3-02 LCD: adım 4, 2 resimden 1. Replacing Nokia X3-02 LCD: adım 4, 2 resimden 2.
    • Remove the keyboard with a plastic opening tool.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Matteo Moro
536 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 4,789
