Ana içeriğe geç
Replacing Oakley Flak 2 Lens and Rubber Kits
Neye ihtiyacın var
  1. Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: adım 1, 3 resimden 1. Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: adım 1, 3 resimden 2. Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pinch the tweezers and place them against the rubber ear socket.
    • Push the tweezers through the hole.
    • Slowly pull out the rubber ear sock.
    • Repeat the previous steps for the other side.
  2. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 2, 2 resimden 1. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 2, 2 resimden 2.
    • Pull up on the bottom of the rubber nose pad.
    • Push the rubber nose pad up to remove it.
    • Repeat the steps for the other side.
  3. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 3, 2 resimden 1. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 3, 2 resimden 2.
    • From the bridge of the glasses, push the bottom outer corner of the lens up.
    • Use the groove to slide the dislodged side of the lens down and out.
  4. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 4, 3 resimden 1. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 4, 3 resimden 2. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 4, 3 resimden 3.
    • Make sure to match the correct ear sock to the correct temple side.
    • Insert the glasses temple in the rubber sock
    • Push/ Pull the rubber sock forward.
    • Push in the rubber tab into the hole near the hinge.
  5. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 5, 3 resimden 1. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 5, 3 resimden 2. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 5, 3 resimden 3.
    • Insert the rubber nose pad from the top.
    • Stretch the nose pad at the bottom and insert the bottom tab into nose pad.
  6. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 6, 3 resimden 1. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 6, 3 resimden 2. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 6, 3 resimden 3.
    • Insert the lens from the outer top corner.
    • Push the bottom corner of the lens closest to the frame's bridge up. An auditable pop will indicate the lens is inserted.
    • Repeat these steps for the other side.
  7. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 7, 2 resimden 1. Replacing Oakley Flak 2 Lens and Rubber Kits: adım 7, 2 resimden 2.
    Microfiber Cleaning Cloths
    $3.99
Sonuç
This guide can allow you to mix and match various rubber kits, and lens to create your own Oakley Flak 2 sunglasses.
2 farklı kişi bu kılavuzu tamamladı.
Peter Tran
193 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 22
Son 30 gün: 47
Her zaman: 2,514
