Ana içeriğe geç
Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock
Neye ihtiyacın var
  1. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock, Locate the Battery/Memory Card Cover Lock.: adım 1, 1 resimden 1.
    • Turn the camera so the bottom is facing upwards.
  2. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: adım 2, 1 resimden 1.
    • First pull open latch to expose two screws covering lock.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: adım 3, 1 resimden 1.
    • Remove the small black lock.
  4. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: adım 4, 1 resimden 1.
    • Turn latch over.
    • There will be one screw visible holding down the cover.
    • Unscrew single screw with your Phillips #00 screwdriver.
  5. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use your tweezers for this step.
    • After unscrewing the screw you will see a single spring.
    • Make sure spring is in place to be able to close lock properly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shannon Cooney
355 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 986
