Ana içeriğe geç
Replacing Samsung Galaxy S4 SIM Card
Neye ihtiyacın var
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: adım 1, 2 resimden 1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: adım 1, 2 resimden 2.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: adım 2, 3 resimden 1. Replacing Samsung Galaxy S4 SIM Card: adım 2, 3 resimden 2. Replacing Samsung Galaxy S4 SIM Card: adım 2, 3 resimden 3.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Yanıt
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Yanıt
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: adım 3, 3 resimden 1. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: adım 3, 3 resimden 2. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: adım 3, 3 resimden 3.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: adım 4, 3 resimden 1. Replacing Samsung Galaxy S4 SIM Card, Battery: adım 4, 3 resimden 2. Replacing Samsung Galaxy S4 SIM Card, Battery: adım 4, 3 resimden 3.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
    it worked for me
    John Donovan - Yanıt
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: adım 5, 3 resimden 1. Replacing Samsung Galaxy S4 SIM Card, SIM Card: adım 5, 3 resimden 2. Replacing Samsung Galaxy S4 SIM Card, SIM Card: adım 5, 3 resimden 3.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
    Looks easy but doesn't work. No one has a plastic opening tool. Using fingernail, you can press SIM card into slot but it does not pop out so you can remove it.
    Laurie McWherter - Yanıt
    I agree with the comment above
    I also don't have a plastic tool and my finger nail won't pop the card out.
    Grethe Montano. September 22
    Grethe Montano - Yanıt
Sonuç
80 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
471.980 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.671 adet Kılavuz yazıldı
3Kılavuz Yorumları
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - Yanıt
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - Yanıt
Removing sim card tray?
G M Chadwick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 31
Son 30 gün: 252
Her zaman: 248,972
