Ana içeriğe geç
Replacing Strings on a Mandolin
Neye ihtiyacın var
  1. Replacing Strings on a Mandolin, Mandolin Strings: adım 1, 1 resimden 1.
    • Place the mandolin on a firm, level surface with adequate lighting.
  2. Replacing Strings on a Mandolin: adım 2, 1 resimden 1.
    • Loosen the tuning nob.
    • Carefully remove the top end of string from the tuner in the mandolin head.
  3. Replacing Strings on a Mandolin: adım 3, 1 resimden 1.
    • Unhook the old string from the tail of the mandolin.
    • Remove the string from the bottom.
  4. Replacing Strings on a Mandolin: adım 4, 1 resimden 1.
    • Select a new string, and then insert the bottom end of it through the bridge at the tail.
  5. Replacing Strings on a Mandolin: adım 5, 1 resimden 1.
    • Secure the string to the tail by looping it over the hook.
  6. Replacing Strings on a Mandolin: adım 6, 1 resimden 1.
    • Pulling the string taut, bring its top end across the nut and into the tuning peg.
  7. Replacing Strings on a Mandolin: adım 7, 1 resimden 1.
    • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
  8. Replacing Strings on a Mandolin: adım 8, 2 resimden 1. Replacing Strings on a Mandolin: adım 8, 2 resimden 2.
    • Pull the string down, towards the fretboard, and run the string underneath itself.
    • Pull the string tight so that it wraps around the tuning peg.
  9. Replacing Strings on a Mandolin: adım 9, 1 resimden 1.
    • Pinch the string over itself to create a knot.
  10. Replacing Strings on a Mandolin: adım 10, 1 resimden 1.
    • Tighten the tuning nob until the desired tension is reached.
  11. Replacing Strings on a Mandolin: adım 11, 1 resimden 1.
    • Clip off any excess string.
  12. Replacing Strings on a Mandolin: adım 12, 1 resimden 1.
    • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
  13. Replacing Strings on a Mandolin: adım 13, 1 resimden 1.
    • Commence rocking on with your Gretsch New Yorker!
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Drew
125 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 30
Her zaman: 7,750
