Ana içeriğe geç
Replacing The PODZ Port
Neye ihtiyacın var
  1. Replacing The PODZ Port, Rear Cover PODZ Port: adım 1, 3 resimden 1. Replacing The PODZ Port, Rear Cover PODZ Port: adım 1, 3 resimden 2. Replacing The PODZ Port, Rear Cover PODZ Port: adım 1, 3 resimden 3.
    • Remove the 6 screws securing the lens cover bezel using a #00 Phillips screwdriver. This will allow you to remove the bezel and lens cover.
  2. Replacing The PODZ Port: adım 2, 1 resimden 1.
    • Remove the metal camera body cover by sliding it toward the lens end of the camera.
  3. Replacing The PODZ Port: adım 3, 1 resimden 1.
    • Remove 2 screws on the bottom of the camera body using a #00 Phillips screwdriver.
  4. Replacing The PODZ Port: adım 4, 1 resimden 1.
    • Remove the 3 screws that secure the camera to the body using a #00 Phillips screwdriver.
  5. Replacing The PODZ Port: adım 5, 1 resimden 1.
    • Use a plastic pry tool to remove the plastic ring covering the rear screws.
  6. Replacing The PODZ Port: adım 6, 2 resimden 1. Replacing The PODZ Port: adım 6, 2 resimden 2.
    • Remove the 8 screws around the perimeter of the back cover.
    • Remove the 2 screws in the PODZ port.
  7. Replacing The PODZ Port: adım 7, 1 resimden 1.
    • Slide PODZ port out of the camera body.
    • Disconnect ribbon cable from the back of the PODZ port.
Sonuç
Christopher Brandl
673 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team S6-G2, Ogden Fall 2018 UW Stout, Team S6-G2, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G2
4 Üyeler
Bir Yorum
How do you reconnect the ribbon cable to the back of the PODZ port when you reassemble?
Peter Niepel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 580
