Giriş
The PODZ port is located on the back face of the Ion Air Pro. This port allows the WI-Fi PODZ Pack accessory to be installed.
Neye ihtiyacın var
Remove the 6 screws securing the lens cover bezel using a #00 Phillips screwdriver. This will allow you to remove the bezel and lens cover.
Slide PODZ port out of the camera body.
Disconnect ribbon cable from the back of the PODZ port.
Either de-solder de microphone black and red wires or cut them midway to rejoin again later to remove the camera from within the housing
Bir Yorum
How do you reconnect the ribbon cable to the back of the PODZ port when you reassemble?
