Ana içeriğe geç
Replacing Toshiba NB205 N330PK Power Button
Neye ihtiyacın var
  1. Replacing Toshiba NB205 N330PK Power Button, Power Button: adım 1, 2 resimden 1. Replacing Toshiba NB205 N330PK Power Button, Power Button: adım 1, 2 resimden 2.
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Replacing Toshiba NB205 N330PK Power Button: adım 2, 2 resimden 1. Replacing Toshiba NB205 N330PK Power Button: adım 2, 2 resimden 2.
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Replacing Toshiba NB205 N330PK Power Button: adım 3, 2 resimden 1. Replacing Toshiba NB205 N330PK Power Button: adım 3, 2 resimden 2.
    • While holding the top of the netbook, flip the netbook over.
  4. Replacing Toshiba NB205 N330PK Power Button: adım 4, 2 resimden 1. Replacing Toshiba NB205 N330PK Power Button: adım 4, 2 resimden 2.
    • Carefully lift off the power bar assembly for access to the button and receiver.
Sonuç
Mason McCaskill
1.021 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G2
3 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 565
