Ana içeriğe geç
Replacing Tungsten E screen. PAL5037
Neye ihtiyacın var
  1. Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: adım 1, 2 resimden 1. Replacing Tungsten E screen. PAL5037, Tungsten E Disassembly: adım 1, 2 resimden 2.
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
    FixBot'a Sor
    Yorum Ekle
  2. Replacing Tungsten E screen. PAL5037: adım 2, 3 resimden 1. Replacing Tungsten E screen. PAL5037: adım 2, 3 resimden 2. Replacing Tungsten E screen. PAL5037: adım 2, 3 resimden 3.
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
    FixBot'a Sor
    Yorum Ekle
  3. Replacing Tungsten E screen. PAL5037: adım 3, 2 resimden 1. Replacing Tungsten E screen. PAL5037: adım 3, 2 resimden 2.
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
    FixBot'a Sor
    Yorum Ekle
  4. Replacing Tungsten E screen. PAL5037: adım 4, 2 resimden 1. Replacing Tungsten E screen. PAL5037: adım 4, 2 resimden 2.
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
    FixBot'a Sor
    Yorum Ekle
  5. Replacing Tungsten E screen. PAL5037: adım 5, 3 resimden 1. Replacing Tungsten E screen. PAL5037: adım 5, 3 resimden 2. Replacing Tungsten E screen. PAL5037: adım 5, 3 resimden 3.
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
    FixBot'a Sor
    Yorum Ekle
  6. Replacing Tungsten E screen. PAL5037: adım 6, 1 resimden 1.
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
    FixBot'a Sor
    Yorum Ekle
  7. Replacing Tungsten E screen. PAL5037, Replacing Touch screen: adım 7, 1 resimden 1.
    • Reassemble the device in the reverse order of the tear down using the new screen in place of the old screen.
    • To reconnect the flex connector press up on the blocks with the spudger to ensure they click into place.
    • Be careful not to damage the flex connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kevin Hom
118 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G22
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 5,922
