Ana içeriğe geç
Replacing a Baseball Bat Grip
Neye ihtiyacın var
  1. Replacing a Baseball Bat Grip, Baseball Bat Grip: adım 1, 3 resimden 1. Replacing a Baseball Bat Grip, Baseball Bat Grip: adım 1, 3 resimden 2. Replacing a Baseball Bat Grip, Baseball Bat Grip: adım 1, 3 resimden 3.
    • Place the bat on a firm surface with the grip hanging off the edge.
    • Draw a line on the top of the old grip using a marker.
    • Practice caution when using the utility knife.
    • Use the utility knife to cut the tape where you made your mark.
    • Peel off the old grip.
    • Some bats may have an under layer of wrap that will require extra peeling to remove.
  2. Replacing a Baseball Bat Grip: adım 2, 2 resimden 1. Replacing a Baseball Bat Grip: adım 2, 2 resimden 2.
    • Put on gloves and place the paper towels under the bat handle to catch the excess spilled residue cleaner.
    • Apply the residue cleaner to the handle.
    • Scrub off the residue with a rag.
  3. Replacing a Baseball Bat Grip: adım 3, 3 resimden 1. Replacing a Baseball Bat Grip: adım 3, 3 resimden 2. Replacing a Baseball Bat Grip: adım 3, 3 resimden 3.
    • Sit in a chair and hold the bat in-between your legs with the knob facing upwards.
    • Take the pre-wrap, begin at the knob of the bat and wrap downward in a spiraling motion toward the mark.
    • When applying the pre-wrap, be sure to keep it evenly layered as it will quickly get thicker when doubled.
    • Stop applying the prewrap at the marked line.
  4. Replacing a Baseball Bat Grip: adım 4, 3 resimden 1. Replacing a Baseball Bat Grip: adım 4, 3 resimden 2. Replacing a Baseball Bat Grip: adım 4, 3 resimden 3.
    • Hold the bat in the same position used for applying the pre-wrap.
    • Apply the electrical tape over the previous wrap using the same motion as before.
    • Be sure to evenly layer the tape to have a smooth wrap all the way down the handle.
  5. Replacing a Baseball Bat Grip: adım 5, 2 resimden 1. Replacing a Baseball Bat Grip: adım 5, 2 resimden 2.
    • Apply a small piece of electrical tape at the beginning and end of the wrap to fasten it to the bat.
    • Now that your new grip is complete, you're ready to play ball!
Bitiş Çizgisi
9 farklı kişi bu kılavuzu tamamladı.
Matthew McNabb
164 İtibar
1 Kılavuz yazıldı
Ekip
Sam Houston State, Team 16-6, Nardone Fall 2015 Sam Houston State, Team 16-6, Nardone Fall 2015 üyesi
SHSU-NARDONE-F15S16G6
5 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
To reverse the previous wrap, try to locate its end. To start from there gently, try using a cutting knife to pull off an end.
The additional stickers you previously applied should be removed after unwinding the tape.
Take off all tape, adhesive, and residue from the bat. Even so, anticipate some goo to be visible on the bat's handle. This can be taken off by gently rubbing it with fine-grit sandpaper. Cut a tiny rectangle out of the sandpaper. When using, use mild, unidirectional strokes.
Be aware of how high you want to wrap your bat before beginning the actual wrapping process. MLB regulations allow grip tape to be applied up to 18 inches up a bat's handle.
Juliet Cyrus - Yanıt
Mathew, you explained quite well. I have linked one picture for your article. The "Baseball bat care"
Do you have to take off the original batting grip?
Abraham CopyWriter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 128
Son 30 gün: 559
Her zaman: 61,948
