Ana içeriğe geç
Replacing a Bissell POWERforce Helix Vacuum Hose
Neye ihtiyacın var
  1. Replacing a Bissell POWERforce Helix Vacuum Hose, Vacuum Hose: adım 1, 1 resimden 1.
    • Remove the single 4 mm Phillips screw that attaches the lower hose to the machine.
  2. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 2, 2 resimden 1. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 2, 2 resimden 2.
    • Set the machine on its side to view the access plate and roller assembly.
  3. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 3, 2 resimden 1. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 3, 2 resimden 2.
    • Remove the six 4 mm Phillips screws that secure the access plate.
  4. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 4, 3 resimden 1. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 4, 3 resimden 2. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 4, 3 resimden 3.
    • Unclip the access plate from the top and bottom.
    • Remove the access plate.
  5. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 5, 2 resimden 1. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 5, 2 resimden 2.
    • Lift up the roller assembly and pull it out towards you.
  6. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 6, 2 resimden 1. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 6, 2 resimden 2.
    • Detach the black upper hose from the clear lower hose.
  7. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 7, 3 resimden 1. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 7, 3 resimden 2. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 7, 3 resimden 3.
    • Remove the lower hose.
  8. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 8, 3 resimden 1. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 8, 3 resimden 2. Replacing a Bissell POWERforce Helix Vacuum Hose: adım 8, 3 resimden 3.
    • Detach the upper hose from the machine.
Sonuç
Aidan Hatch
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-9, Andersen Winter 2024 UC Davis, Team 2-9, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S2G9
2 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 60
