Ana içeriğe geç
Replacing a Broken/Cracked Window Blind Slat
Neye ihtiyacın var
  1. Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: adım 1, 2 resimden 1. Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: adım 1, 2 resimden 2.
    • Adjust the angle of the blinds until every slat is flat or laying horizontally using the blind's wand.
  2. Replacing a Broken/Cracked Window Blind Slat: adım 2, 3 resimden 1. Replacing a Broken/Cracked Window Blind Slat: adım 2, 3 resimden 2. Replacing a Broken/Cracked Window Blind Slat: adım 2, 3 resimden 3.
    • Carefully remove the damaged slat by cutting the slant halfway across its width, at the point where it is connected to the rest of the blind, with a pair of 8-inch 'Westcott' scissors.
    • Remove the damaged slat from the blind after it has been cut on both sides.
  3. Replacing a Broken/Cracked Window Blind Slat: adım 3, 1 resimden 1.
    • Choose an un-cracked slat from a part of the blind that is unaffected during normal use - preferably from the very bottom of the blind.
  4. Replacing a Broken/Cracked Window Blind Slat: adım 4, 3 resimden 1. Replacing a Broken/Cracked Window Blind Slat: adım 4, 3 resimden 2. Replacing a Broken/Cracked Window Blind Slat: adım 4, 3 resimden 3.
    • Carefully cut the selected slat halfway across its width, at its two connected points.
    • Carefully remove the replacement slat from its old position, making sure to not extend the cut you made past halfway of the slats width.
  5. Replacing a Broken/Cracked Window Blind Slat: adım 5, 3 resimden 1. Replacing a Broken/Cracked Window Blind Slat: adım 5, 3 resimden 2. Replacing a Broken/Cracked Window Blind Slat: adım 5, 3 resimden 3.
    • Carefully place the replacement slat it into its new position.
    • Connect the replacement slat to the support strings at the points where the cuts were made.
  6. Replacing a Broken/Cracked Window Blind Slat: adım 6, 3 resimden 1. Replacing a Broken/Cracked Window Blind Slat: adım 6, 3 resimden 2. Replacing a Broken/Cracked Window Blind Slat: adım 6, 3 resimden 3.
    • Tear off a small piece of invisible tape from the roll of tape and carefully place it over the cuts that were made on the replacement slat.
    • Apply tape over the top and bottom of the cuts, on both sides of the replacement slat.
  7. Replacing a Broken/Cracked Window Blind Slat: adım 7, 2 resimden 1. Replacing a Broken/Cracked Window Blind Slat: adım 7, 2 resimden 2.
    • Twist the wand of the window blind to test it after applying the tape to both sides of the replacement slat.
    • If the replacement slat stays in its new position then congratulations, you have completed the fix!
Sonuç
Moses Matovu
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 43
Son 30 gün: 146
Her zaman: 5,114
