Ana içeriğe geç
Replacing a Sprinkler Extension
Neye ihtiyacın var
  1. Replacing a Sprinkler Extension, Sprinkler Extension: adım 1, 1 resimden 1.
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: adım 2, 1 resimden 1.
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: adım 3, 1 resimden 1.
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: adım 4, 2 resimden 1. Replacing a Sprinkler Extension: adım 4, 2 resimden 2.
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: adım 5, 1 resimden 1.
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: adım 6, 2 resimden 1. Replacing a Sprinkler Extension: adım 6, 2 resimden 2.
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
Sonuç
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
111 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,070
