Ana içeriğe geç
Replacing a TAE/DSL Socket with a RJ45 Jack
Neye ihtiyacın var
  1. Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: adım 1, 2 resimden 1. Replacing a TAE/DSL Socket with a RJ45 Jack, Remove the old socket: adım 1, 2 resimden 2.
    • Unscrew and remove the cover.
    • If you want to add a RJ45 jack but only have the first outlet, that you can’t replace, to work with, you can just mount the new outlet next to the old one. You’ll need to connect La to 6 and Lb to 5. You can use any kind of shielded twisted pair cable to wire the new outlet.
    • Remove the the connections.
    • Keep track of La and Lb. You’ll need to know what wires to connect where in the new socket.
    • Unscrew the socket from the wall.
  2. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the new socket: adım 2, 1 resimden 1.
    • Screw the new socket cover to the wall.
    • Refer to the manual that came with your outlet for this step.
  3. Replacing a TAE/DSL Socket with a RJ45 Jack, Punch down the wires: adım 3, 1 resimden 1.
    • If you don’t know how to use a punch down tool, take a look at this guide first.
    • Connect La to pin 4 (Blue).
    • Connect Lb to pin 5 (White-Blue).
  4. Replacing a TAE/DSL Socket with a RJ45 Jack, Mount the socket: adım 4, 1 resimden 1.
    • Mount the RJ45 socket inside the case and screw on the faceplate.
Sonuç
Have fun surfing the web!
Sebastian
28.626 İtibar
71 adet Kılavuz yazıldı
Ekip
German Translators German Translators üyesi
Community
35 Üyeler
1.222 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 231
Son 30 gün: 927
Her zaman: 13,027
