Ana içeriğe geç
Replacing flash memory to a cisco 837 series router
Neye ihtiyacın var
  1. Replacing flash memory to a cisco 837 series router, Flash memory: adım 1, 1 resimden 1.
    • CISCO 837 Router
    • CISCO 877 Router
Sonuç
CONCLUSION
Replacing flash need a tftp server available;
Replacing flash need a copy of the IOS image;
Replacing flash need the usage of ROMMON; be sure that this is possible;
Removing the flash card and inserting it back is like replacing with a new one (IOS image will be gone, so don’t play it with ease);
use the first ethernet port to connect with the tftp server, although all 4 switch ports will work presumably because all being in the same first VLAN.
To reassemble your device, follow these instructions in reverse order and that's all.
Bir başkası bu kılavuzu tamamladı.
Eneider Colina
2.370 İtibar
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,478
