Ana içeriğe geç
Replacing the Audio Jack on a Hofner Violin Bass
Neye ihtiyacın var
  1. Replacing the Audio Jack on a Hofner Violin Bass, 1/4" output jack: adım 1, 2 resimden 1. Replacing the Audio Jack on a Hofner Violin Bass, 1/4" output jack: adım 1, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the jack plate from the bottom corner of the guitar.
    • Place the components in your container in order to keep track of them.
  2. Replacing the Audio Jack on a Hofner Violin Bass: adım 2, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the four screws attaching the control panel to the instrument.
  3. Replacing the Audio Jack on a Hofner Violin Bass: adım 3, 2 resimden 1. Replacing the Audio Jack on a Hofner Violin Bass: adım 3, 2 resimden 2.
    • Locate the jack if it has fallen inside the guitar.
    • Pull the jack and attached wire through the jack hole.
  4. Replacing the Audio Jack on a Hofner Violin Bass: adım 4, 1 resimden 1.
    • Proceed with soldering only when working in a well ventilated area.
    • Warning. When soldering, the tip and shaft of the soldering iron will become extremely hot. Avoid contact.
    • Using your soldering iron, melt the solder connecting the ground wire to the old jack.
  5. Replacing the Audio Jack on a Hofner Violin Bass: adım 5, 3 resimden 1. Replacing the Audio Jack on a Hofner Violin Bass: adım 5, 3 resimden 2. Replacing the Audio Jack on a Hofner Violin Bass: adım 5, 3 resimden 3.
    • Using your wire stripper tool, cut the end of the wire off.
    • Then, strip the wire so it looks similar to the wire in the red box.
  6. Replacing the Audio Jack on a Hofner Violin Bass: adım 6, 3 resimden 1. Replacing the Audio Jack on a Hofner Violin Bass: adım 6, 3 resimden 2. Replacing the Audio Jack on a Hofner Violin Bass: adım 6, 3 resimden 3.
    • Now we will prep the wire for soldering.
    • Secure the wire using the helping hands tool.
    • Heat one of the conductors with the soldering iron.
    • Maintaining contact between the iron and wire, carefully apply solder to the conductor.
    • Repeat this process for the other conductor.
  7. Replacing the Audio Jack on a Hofner Violin Bass: adım 7, 2 resimden 1. Replacing the Audio Jack on a Hofner Violin Bass: adım 7, 2 resimden 2.
    • Next, prep the jack for soldering.
    • Secure the jack using the helping hands tool.
    • Apply the iron to the first conductor tab to heat it.
    • Now apply the solder to the heated tab.
    • Repeat this process for the second conductor tab.
  8. Replacing the Audio Jack on a Hofner Violin Bass: adım 8, 3 resimden 1. Replacing the Audio Jack on a Hofner Violin Bass: adım 8, 3 resimden 2. Replacing the Audio Jack on a Hofner Violin Bass: adım 8, 3 resimden 3.
    • Now we will proceed to solder the components.
    • Touch the hot wire to the hot conductor tab and heat with the soldering iron until they melt together.
    • Repeat this process, connecting the ground wire to the ground conductor tab.
  9. Replacing the Audio Jack on a Hofner Violin Bass: adım 9, 3 resimden 1. Replacing the Audio Jack on a Hofner Violin Bass: adım 9, 3 resimden 2. Replacing the Audio Jack on a Hofner Violin Bass: adım 9, 3 resimden 3.
    • Put the first nut on the output jack shaft.
    • Place the jack plate on the shaft.
    • Put the second nut on the shaft, tightening with a crescent wrench.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Bryan Newbold
124 İtibar
1 Kılavuz yazıldı
Bir Yorum
What size guitar nut do you use? i need to find just the nut on its own
Corey Powell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 47
Her zaman: 2,990
