Ana içeriğe geç
Replacing the Battery on a BLU Vivo 5
Neye ihtiyacın var
  1. Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: adım 1, 2 resimden 1. Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: adım 1, 2 resimden 2.
    • Remove the P2 screws.
    • Remove the SIM and SD cards, as well as the adapter.
  2. Replacing the Battery on a BLU Vivo 5, Remove the top cover.: adım 2, 3 resimden 1. Replacing the Battery on a BLU Vivo 5, Remove the top cover.: adım 2, 3 resimden 2. Replacing the Battery on a BLU Vivo 5, Remove the top cover.: adım 2, 3 resimden 3.
    • Pull off the protective cover from the camera.
    • Remove the screws with a #00 Phillips screwdriver.
  3. Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: adım 3, 3 resimden 1. Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: adım 3, 3 resimden 2. Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: adım 3, 3 resimden 3.
    • To remove the bottom cover, pull it upward.
  4. Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: adım 4, 3 resimden 1. Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: adım 4, 3 resimden 2. Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: adım 4, 3 resimden 3.
    • Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
    • Remove the microphone/speaker board assembly by pulling downward.
  5. Replacing the Battery on a BLU Vivo 5, Removing the battery.: adım 5, 3 resimden 1. Replacing the Battery on a BLU Vivo 5, Removing the battery.: adım 5, 3 resimden 2. Replacing the Battery on a BLU Vivo 5, Removing the battery.: adım 5, 3 resimden 3.
    • The battery has a small notch to facilitate removal, but the battery has been glued in place.
    • To remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
es en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Eneider Colina
2.362 İtibar
9 adet Kılavuz yazıldı
Ekip
Comunidad para traductores de español Comunidad para traductores de español üyesi
Community
24 Üyeler
246 adet Kılavuz yazıldı
2 Yorum
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
V'Ger_iTech - Yanıt
This guide is NOT for BLU Vivo 5. It's probably for the mini version. The BLU vivo 5 doesn't have screws at bottom...
Alaziz Hussain - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 3,960
