Ana içeriğe geç
  1. Before starting, extract the SIM tray.
    • Before starting, extract the SIM tray.
  2. Torx #2 Pry in between the screen and the back cover. All electronic components are on the back of the screen.
    • Torx #2
    • Pry in between the screen and the back cover. All electronic components are on the back of the screen.
  3. Disconnect the fingerprint reader.
    • Disconnect the fingerprint reader.
  4. Remove the battery, lower PCB and screen connector bracket. Use a Philips #0 screwdriver. Screen connector
    • Remove the battery, lower PCB and screen connector bracket. Use a Philips #0 screwdriver.
    • Screen connector
  5. Connect and test the new screen before assembling it.
    • Connect and test the new screen before assembling it.
  6. Philips #0 Disconnect speaker Remove speaker
    • Philips #0
    • Disconnect speaker
    • Remove speaker
    • Apply heat on the top and bottom of the screen until it can be removed with the prying tools. Remove as much adhesive as possible and assemble the new screen.
Sonuç
Follow these instructions in reverse order to reassemble your device.
4 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
es en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Cesar Roman
354 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 39
Her zaman: 3,135
