Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Replacing the Macintosh PowerBook 1400c Monitor
Neye ihtiyacın var
  1. Replacing the Macintosh PowerBook 1400c Monitor, Battery: adım 1, 1 resimden 1.
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Replacing the Macintosh PowerBook 1400c Monitor: adım 2, 1 resimden 1.
    • Slide the latch to the left to release the battery.
  3. Replacing the Macintosh PowerBook 1400c Monitor: adım 3, 1 resimden 1.
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Replacing the Macintosh PowerBook 1400c Monitor, CD-ROM Drive: adım 4, 1 resimden 1.
    • Locate the CD-ROM Drive latch.
  5. Replacing the Macintosh PowerBook 1400c Monitor: adım 5, 1 resimden 1.
    • Slide the latch to the right to release the CD ROM drive.
  6. Replacing the Macintosh PowerBook 1400c Monitor: adım 6, 1 resimden 1.
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Replacing the Macintosh PowerBook 1400c Monitor, Keyboard: adım 7, 1 resimden 1.
    • Locate the speaker cover.
  8. Replacing the Macintosh PowerBook 1400c Monitor: adım 8, 1 resimden 1.
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Replacing the Macintosh PowerBook 1400c Monitor: adım 9, 1 resimden 1.
    • Gently lift the speaker cover to remove it.
  10. Replacing the Macintosh PowerBook 1400c Monitor: adım 10, 1 resimden 1.
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Replacing the Macintosh PowerBook 1400c Monitor: adım 11, 1 resimden 1.
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Replacing the Macintosh PowerBook 1400c Monitor: adım 12, 1 resimden 1.
    • Tilt the keyboard away from the screen.
  13. Replacing the Macintosh PowerBook 1400c Monitor: adım 13, 1 resimden 1.
    • Locate the six screws that secure the heatsink.
  14. Replacing the Macintosh PowerBook 1400c Monitor: adım 14, 1 resimden 1.
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Replacing the Macintosh PowerBook 1400c Monitor: adım 15, 1 resimden 1.
    • Lift the heatsink from the side closest to the laptop screen.
  16. Replacing the Macintosh PowerBook 1400c Monitor: adım 16, 1 resimden 1.
    • Remove the heatsink.
  17. Replacing the Macintosh PowerBook 1400c Monitor: adım 17, 1 resimden 1.
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Replacing the Macintosh PowerBook 1400c Monitor: adım 18, 1 resimden 1.
    • Detach the ribbon cable.
  19. Replacing the Macintosh PowerBook 1400c Monitor: adım 19, 1 resimden 1.
    • Remove the keyboard.
  20. Replacing the Macintosh PowerBook 1400c Monitor, Monitor: adım 20, 1 resimden 1.
    • Identify the right and left monitor end caps.
  21. Replacing the Macintosh PowerBook 1400c Monitor: adım 21, 1 resimden 1.
    • Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
  22. Replacing the Macintosh PowerBook 1400c Monitor: adım 22, 1 resimden 1.
    • Once the end cap has been loosened by the spudger, pull outwards on the end caps.
  23. Replacing the Macintosh PowerBook 1400c Monitor: adım 23, 1 resimden 1.
    • Completely remove both end caps.
  24. Replacing the Macintosh PowerBook 1400c Monitor: adım 24, 1 resimden 1.
    • Identify the 4 total screw under the end caps (2 under each end cap).
    • The two outside 16mm long screws
    • The two inside 5.4mm long screws
  25. Replacing the Macintosh PowerBook 1400c Monitor: adım 25, 1 resimden 1.
    • Lay the monitor all the way back.
  26. Replacing the Macintosh PowerBook 1400c Monitor: adım 26, 1 resimden 1.
    • Remove the 4 screws using the Phillips #0 screwdriver.
  27. Replacing the Macintosh PowerBook 1400c Monitor: adım 27, 1 resimden 1.
    • Identify the center cap of the monitor.
  28. Replacing the Macintosh PowerBook 1400c Monitor: adım 28, 1 resimden 1.
    • Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
  29. Replacing the Macintosh PowerBook 1400c Monitor: adım 29, 1 resimden 1.
    • Detach the center cap completely.
  30. Replacing the Macintosh PowerBook 1400c Monitor: adım 30, 1 resimden 1.
    • Identify the one 12.6mm long screw under the center cap.
  31. Replacing the Macintosh PowerBook 1400c Monitor: adım 31, 1 resimden 1.
    • Remove the center screw with a Phillips #0 screwdriver.
  32. Replacing the Macintosh PowerBook 1400c Monitor: adım 32, 1 resimden 1.
    • Lift upwards on the metal cover under the screw.
  33. Replacing the Macintosh PowerBook 1400c Monitor: adım 33, 1 resimden 1.
    • Completely remove the metal cover.
  34. Replacing the Macintosh PowerBook 1400c Monitor: adım 34, 1 resimden 1.
    • Identify where the left and right monitor cords are attached to the logic board
    • The base of the left monitor cord
    • The base of the right monitor cord
  35. Replacing the Macintosh PowerBook 1400c Monitor: adım 35, 1 resimden 1.
    • To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
  36. Replacing the Macintosh PowerBook 1400c Monitor: adım 36, 1 resimden 1.
    • Completely detach the left monitor cord from the logic board.
  37. Replacing the Macintosh PowerBook 1400c Monitor: adım 37, 1 resimden 1.
    • To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
  38. Replacing the Macintosh PowerBook 1400c Monitor: adım 38, 1 resimden 1.
    • Completely detach the right monitor cord from the logic board.
  39. Replacing the Macintosh PowerBook 1400c Monitor: adım 39, 1 resimden 1.
    • Completely remove the monitor from the computer.
Sonuç
Once the monitor has been removed, to attach the new monitor follow these instructions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
Taylor Chris
187 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 üyesi
CPSU-FORTE-S11S10G39
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 4,169
