Ana içeriğe geç
Replacing the Metal Plate Holding the Leg of an Ironing Board
Neye ihtiyacın var
  1. Replacing the Metal Plate Holding the Leg of an Ironing Board, Metal plate holding the leg of the ironing board: adım 1, 1 resimden 1.
    • Place the ironing board face down on a flat, stable surface.
  2. Replacing the Metal Plate Holding the Leg of an Ironing Board: adım 2, 1 resimden 1.
    • Unscrew and remove the broken metal plate.
  3. Replacing the Metal Plate Holding the Leg of an Ironing Board: adım 3, 1 resimden 1.
    • Cut the metal sheet into an appropriate size.
    • Use cut proof gloves for protection
  4. Replacing the Metal Plate Holding the Leg of an Ironing Board: adım 4, 1 resimden 1.
    • Using a 1/8" drill bit, drill four holes on each corner where the screws will be placed.
  5. Replacing the Metal Plate Holding the Leg of an Ironing Board: adım 5, 1 resimden 1.
    • On the corner of a flat edge, use a mallet to shape the metal sheet.
    • Keep your hand at a distance from the mallet to avoid hitting your fingers.
  6. Replacing the Metal Plate Holding the Leg of an Ironing Board: adım 6, 1 resimden 1.
    • Using a screwdriver, screw on the new plate with the #10-32 x 3/8" pan-headed screws.
  7. Replacing the Metal Plate Holding the Leg of an Ironing Board: adım 7, 2 resimden 1. Replacing the Metal Plate Holding the Leg of an Ironing Board: adım 7, 2 resimden 2.
    • Finish repairing the iron board!
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Nina Youn
211 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G1, Bender Fall 2018 UC Davis, Team S2-G1, Bender Fall 2018 üyesi
UCD-BENDER-F18S2G1
4 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 3,003
