Ana içeriğe geç
Replacing the Slider on a Coil Zipper
Neye ihtiyacın var
Videoya Genel Bakış
  1. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: adım 1, 3 resimden 1. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: adım 1, 3 resimden 2. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: adım 1, 3 resimden 3.
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Replacing the Slider on a Coil Zipper: adım 2, 2 resimden 1. Replacing the Slider on a Coil Zipper: adım 2, 2 resimden 2.
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
  3. Replacing the Slider on a Coil Zipper: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully remove any remaining pieces of the stop using tweezers.
  4. Replacing the Slider on a Coil Zipper: adım 4, 3 resimden 1. Replacing the Slider on a Coil Zipper: adım 4, 3 resimden 2. Replacing the Slider on a Coil Zipper: adım 4, 3 resimden 3.
    • Slide the damaged zipper slider up and off of the zipper.
  5. Replacing the Slider on a Coil Zipper: adım 5, 2 resimden 1. Replacing the Slider on a Coil Zipper: adım 5, 2 resimden 2.
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  6. Replacing the Slider on a Coil Zipper: adım 6, 2 resimden 1. Replacing the Slider on a Coil Zipper: adım 6, 2 resimden 2.
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  7. Replacing the Slider on a Coil Zipper: adım 7, 3 resimden 1. Replacing the Slider on a Coil Zipper: adım 7, 3 resimden 2. Replacing the Slider on a Coil Zipper: adım 7, 3 resimden 3.
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
Bitiş Çizgisi
19 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
89.128 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.076 adet Kılavuz yazıldı
11 Yorum
Where do I get the zipper stop????
Jason Heimink - Yanıt
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Yanıt
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Yanıt
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Yanıt
Great now how ! thank’s :)
Robert Fyfe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 66
Son 30 gün: 460
Her zaman: 100,258
