Ana içeriğe geç
Replacing the power switch on a Blaupunkt LCD TV BW39B68BFBKUE480
Neye ihtiyacın var
    • Make sure that the device is disconnected from the power supply before starting the repair.
    • Removing the power switch is quite simple. First open the housing by removing all the screws on the rear panel, which are marked with an arrow.
    • The screws have different lengths and strengths. Make note of which screw goes where.
    • Then carefully lift off the back panel and disconnect any cables that prevent the back panel from being lifted off.
    • Now press the retaining clips that hold the switch in the TV housing together with needle-nose pliers and clip the switch out of the TV housing. Use a flat-blade screwdriver to assist with that if necessary.
    • You should have some electrotechnical knowledge so that you will be able to correctly position the connectors on the new switch.
    • Now just clip on the switch. Plug in the disconnected cables. Fit rear panel and screw in all screws again.
    • Description on the original switch: LECI RS601D more details 6 (4) A250VAC new line: 10A 125VAC - other side: 6A250VAC new line: 6A / 125A250VAC -
    • My problem was that the power switch was broken and the TV could only be switched on sporadically.
    • On Ebay, the switch RS601D (as of June 2017), is available as an original from China. An alternative: Since I just had it on hand, I installed the following switch from Pollin: # 420427 (unfortunately, no indication of inrush current found)
    • Probably also suitable: Marquardt 1858.1103 rocker switch, black, plug-in 4.8 mm, 10 (4.0) A / 250 VAC, 6.0 (4.0) A / 250 VAC e.g. from Bürklin: # 11 G 2854 - € 1.94
Sonuç
As already mentioned - connect the cable to the new switch and snap the snap-in switch back into the housing. Replace the rear panel and screw the screws back in where they were unscrewed.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
dieter
325 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 853
