Ana içeriğe geç
ResMed AirSense 10 Heater Fuse Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: adım 1, 2 resimden 1. ResMed AirSense 10  Heater Fuse Replacement, Heater Plate Fuse: adım 1, 2 resimden 2.
    • With medium pressure, place your thumb on the top of the tank and four fingers on the bottom.
    • Pull straight out on the tank until it releases from the device.
    FixBot'a Sor
    Yorum Ekle
  2. ResMed AirSense 10  Heater Fuse Replacement: adım 2, 1 resimden 1.
    • Remove the four 10mm screws from the bottom of the device with a Torx T10 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. ResMed AirSense 10  Heater Fuse Replacement: adım 3, 3 resimden 1. ResMed AirSense 10  Heater Fuse Replacement: adım 3, 3 resimden 2. ResMed AirSense 10  Heater Fuse Replacement: adım 3, 3 resimden 3.
    • After the plastic cover has been removed you will be able to see the back of the heater plate. We will remove it from the device to making it easier to remove the fuse.
    • Pinching the three red cords, pull straight back on the heater plate power cord until it is removed from the connector.
    • After the cord has been removed from the connector, it will need to be pulled through the rubber grommet.
    • Gently pull the wires to the connector until the white connector is touching the rubber grommet.
    • Using light force, push the white connector on the end of the heater plate power cords through the rubber grommet.
    FixBot'a Sor
    Yorum Ekle
  4. ResMed AirSense 10  Heater Fuse Replacement: adım 4, 3 resimden 1. ResMed AirSense 10  Heater Fuse Replacement: adım 4, 3 resimden 2. ResMed AirSense 10  Heater Fuse Replacement: adım 4, 3 resimden 3.
    • Using the straight tipped tweezers, push the fuse away from fuse housing until the main body of the fuse is visible.
    • Take the straight tipped tweezers, grip the body of the fuse, and pull it free from the housing.
    • Make sure to not bend the wire of the fuse. Using the holes of the housing as a guide will allow you to put the fuse back in the correct orientation.
    FixBot'a Sor
    Yorum Ekle
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
39Kılavuz Yorumları
Where can I buy a new fuse? This one does not look like one I can get at a hardware store.
pnreinhard - Yanıt Paylaş
Yws, please, where can we buy a new fuse? Thanks.
mustdeliver - Yanıt Paylaş
and yes where do you buy a fuse can’t find no where PLEASE @ cityboi53@yahoo.com
citycountryboi53 - Yanıt Paylaş
Did you get a reply as to where you can buy the fuse?
Wally Petrey - Yanıt Paylaş
any idea how can i get the fuse what are the specs and where can i buy one or someone know where to get the whole heating plate
andres usma - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 85
Son 30 gün: 410
Her zaman: 47,015
