Giriş
If the humidifier function in your ResMed Airsense 10 ventilator has stopped working, a simple replacement of the heater fuse may solve the problem. This guide will also provide you with the information to completely replace the Heater Plate as well.
Neye ihtiyacın var
With medium pressure, place your thumb on the top of the tank and four fingers on the bottom.
Pull straight out on the tank until it releases from the device.
Pinching the three red cords, pull straight back on the heater plate power cord until it is removed from the connector.
Gently pull the wires to the connector until the white connector is touching the rubber grommet.
Using light force, push the white connector on the end of the heater plate power cords through the rubber grommet.
12 farklı kişi bu kılavuzu tamamladı.
27 Yorum
Where can I buy a new fuse? This one does not look like one I can get at a hardware store.
Yws, please, where can we buy a new fuse? Thanks.
and yes where do you buy a fuse can’t find no where PLEASE @ cityboi53@yahoo.com
Did you get a reply as to where you can buy the fuse?
any idea how can i get the fuse what are the specs and where can i buy one or someone know where to get the whole heating plate
