Ana içeriğe geç
ResMed VPAP Auto 25 Blower Unit Replacement Replacement
Neye ihtiyacın var
  1. ResMed VPAP Auto 25 Blower Unit Replacement Replacement, Blower Unit: adım 1, 3 resimden 1. ResMed VPAP Auto 25 Blower Unit Replacement Replacement, Blower Unit: adım 1, 3 resimden 2. ResMed VPAP Auto 25 Blower Unit Replacement Replacement, Blower Unit: adım 1, 3 resimden 3.
    • Remove the four 26.7 mm T3 Torx screws from the bottom side of the ResMed VPAP Auto 25.
  2. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 2, 3 resimden 1. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 2, 3 resimden 2. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 2, 3 resimden 3.
    • Flip the device over.
    • Pry the outermost plastic cover off with the metal spudger until the cover is loose and able to be removed.
  3. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 3, 2 resimden 1. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 3, 2 resimden 2.
    • Pull off the front cover to reveal the internal components.
  4. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 4, 3 resimden 1. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 4, 3 resimden 2. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 4, 3 resimden 3.
    • Loosen the motherboard from the rubber dowels holding it in place and unplug the screen components.
  5. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 5, 3 resimden 1. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 5, 3 resimden 2. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 5, 3 resimden 3.
    • Remove the three 26.7 mm T3 Torx screws from the now visible rubber fan motor cover.
    • Lift off the rubber fan motor cover, revealing the fan motor.
  6. ResMed VPAP Auto 25 Blower Unit Replacement Replacement: adım 6, 1 resimden 1.
    • Unplug the blower unit cable.
    • Remove the fan motor blower unit.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
where can we get a new motor?
ed allen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 307
