Giriş
Use this guide to restore water-stained UGG boots.
When exposed to rain or puddles, UGG boots may develop water stains on the sheepskin, making them look less appealing. Our walkthrough offers detailed instructions and the necessary materials to effectively remove these stains, emphasizing gentle techniques to protect the boots. Save your UGGs from permanent harm and the need for replacement by following this comprehensive guide.
Exercise caution throughout the restoration process for optimal results, and ensure the boots are kept out of direct sunlight when drying.
Neye ihtiyacın var
Use the sponge to lightly dampen the outer surface of your boots with cold water (do NOT soak as it will damage fabric).
Apply a small amount of the sheepskin cleaner and conditioner on a wet sponge and gently rub the problem areas on the exterior of the UGG boots. Note: Scrubbing vigorously can cause damage
Stuff newspaper or paper towels into the boots to help maintain their shape.
Place the UGG boots in a dry and well-ventilated area away from direct sunlight to dry (Do not use heat to speed up the process).
