Ana içeriğe geç
Resetting PlayStation 3 Drive Mechanism
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Resetting PlayStation 3 Drive Mechanism, Resetting PlayStation 3 Drive Mechanism: adım 1, 1 resimden 1.
    • Remove Rubber Foot
  2. Resetting PlayStation 3 Drive Mechanism: adım 2, 1 resimden 1.
    • Remove Screw with a TORX Security T10 Bit (or you can use a small flat head screwdriver)
  3. Resetting PlayStation 3 Drive Mechanism: adım 3, 1 resimden 1.
    • Carefully slide the top plate and lift to remove
  4. Resetting PlayStation 3 Drive Mechanism: adım 4, 1 resimden 1.
    • Remove the main screws (philips head)
  5. Resetting PlayStation 3 Drive Mechanism: adım 5, 1 resimden 1.
    • Lift The Top Casing Towards the front of the PS3 carefully
  6. Resetting PlayStation 3 Drive Mechanism: adım 6, 1 resimden 1.
    • Carefully Remove Power cable from the motherboard
  7. Resetting PlayStation 3 Drive Mechanism: adım 7, 1 resimden 1.
    • Lift the Disk drive to the right and remove the largest ribbon cable by lifting the black catch and remove the drive from the PS3
  8. Resetting PlayStation 3 Drive Mechanism: adım 8, 1 resimden 1.
    • Remove Screws 11, 12 and 13 only
  9. Resetting PlayStation 3 Drive Mechanism: adım 9, 1 resimden 1.
    • Remove screws 14 and 15 and the silver springboard, slightly bend top metal away from disk entry area,and pull back to remove the metal jacket.
  10. Resetting PlayStation 3 Drive Mechanism: adım 10, 1 resimden 1.
    • Remove white center hub piece (D) and screws 16 - 20 then fold the top section to the left being careful not to damage the cable to the bottom left. The cable is very delicate and easily damaged.
  11. Resetting PlayStation 3 Drive Mechanism: adım 11, 1 resimden 1.
    • Remove the screw circled in red and lift up the black assembly to reveal the mechanism beneath. Set it aside right-side up and be careful not to shake any parts loose.
  12. Resetting PlayStation 3 Drive Mechanism: adım 12, 1 resimden 1.
    • Remove two screws in blue and lift the motor up and to right to disengage the cogs but be careful not to stress the attached wires.
    • Move the disc handling element on the left side up so that its teeth are clear of the black cog.
    • Reset insertion trap lock mechanism and make sure the white tab on right is lowered (nudge it left to make it drop).
    • Replace the motor and reverse this guide to reassemble.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
David Harris
816 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 15,927
