Ana içeriğe geç
Resetting the Clock
  1. Resetting the Clock, Resetting the Clock: adım 1, 1 resimden 1.
    • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
    FixBot'a Sor
    Yorum Ekle
  2. Resetting the Clock: adım 2, 2 resimden 1. Resetting the Clock: adım 2, 2 resimden 2.
    • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
    FixBot'a Sor
    Yorum Ekle
  3. Resetting the Clock: adım 3, 1 resimden 1.
    • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
    FixBot'a Sor
    Yorum Ekle
  4. Resetting the Clock: adım 4, 1 resimden 1.
    • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
    FixBot'a Sor
    Yorum Ekle
  5. Resetting the Clock: adım 5, 1 resimden 1.
    • Press the "VOLUME +" button to advance the minutes forward.
    FixBot'a Sor
    Yorum Ekle
  6. Resetting the Clock: adım 6, 1 resimden 1.
    • Press the "VOLUME -" button to decrease the minutes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
Jacob Aube
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G50
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 1,811
