Ana içeriğe geç
Retina MacBook 2015 Upper Case Assembly Replacement
Neye ihtiyacın var
  1. Retina MacBook 2015 Upper Case Assembly Replacement, Unfasten the lower case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If, like me, you didn’t have a P5 Pentalope screwdriver but did have one that fits an iPhone.
    You can sand down the tip until it’s the right size.
    Stuart - Yanıt
    Thank you Stuart! I would never have thought of this and it worked perfectly.
    R McP -
    Hello,
    where do I plug the USB-C to USB-A cable on MacBook MacBook Pro (Retina, 15-inch, Mid 2015)
    I can’t any port suitable for USB-c !??
    sissi - Yanıt
    My MacBook had P4 pentalobe screws, notP5
    Greg Lavardera - Yanıt
    Big thanks to Jeff for such thorough and detailed instructions. This is definitely a more advanced repair so if you're not comfortable with making such repairs, like having experience working on iPhones, computers, etc., you might think twice before attempting. It's very helpful to read all the instructions thoroughly before starting. Plan on 3 to 4 hours—the battery removal along with its adhesive is a real $@$*-show, but totally doable if you followed Jeff's recommendations.
    I'll post a few tips in the comments on each step that I think is worth noting but I will mention here one of the trickier steps. ZIF connectors on the flat cables can be a little tricky, especially if you have never done these. Before attempting to do the first one (step 8) review the others in steps 16, 20, and 25. You'll get a better sense of how these little retaining flaps flip up and what they actually look like when you study each photo in each step—they are very tiny and fragile.
    Steven Gibson - Yanıt
    Just finished replacing the battery. I followed the directions that came with the battery instead of this guide. In short, Steps 15 to 35 are not necessary. You don't have to completely disassemble the laptop to replace the battery.
    Andrew Mohan - Yanıt
    Thanks. I skipped it too and it worked.. It was a painstaking to remove the two side batteries as the cables were connected. But a little patience gets the job done. I did however remove the audio jack connector but from the audio board. Removed the display connector and the usb-c bracket to get the bottom case free.
    Paras Tolani -
    READ EVERY STEP, AND EVERY COMMENT FOR THAT STEP BEFORE ATTEMPTING! Go slow. Think first. Be organized. No probs.
    David Nagle - Yanıt
  2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 2, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 2, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 2, 3 resimden 3.
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  3. Retina MacBook 2015 Upper Case Assembly Replacement: adım 3, 1 resimden 1.
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  4. Retina MacBook 2015 Upper Case Assembly Replacement: adım 4, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 4, 2 resimden 2.
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    This step at the suggested height tears the ribbon cable. do step 7 first. carefully
    Kiernan - Yanıt
    If you carefully open the display all the way and then lift the upper case, you can let the display rest on your flat working surface. The upper case will be held in place at an appropriate angle by the display hinge.
    Mike C - Yanıt
    It's a two-spooger-job.
    LMAOOOOOOOO
    Elixir2 - Yanıt
  5. Retina MacBook 2015 Upper Case Assembly Replacement: adım 5, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 5, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 5, 3 resimden 3.
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
    Wow okay could someone explain why this is necessary? What happens if you skip this step and simply undo the screw to disconnect the power?
    EB Computers - Yanıt
    Removing the screw does not disconnect the power—power comes from the battery terminals contacting the underside of the logic board, and they’re tricky to separate reliably at this stage of disassembly. This step is the safest and easiest way to kill power; don’t skip it.
    Jeff Suovanen -
    What if I can’t get my LED to power on when reassembling the machine?
    greg2b - Yanıt
    Update: Realized my USB-C connector (Step 14) wasn’t properly seated.
    greg2b -
    Hi what will happen if i skip this step, coz i did tried to power down the battery by pressing small gold button, but no avail. the LED light still there even after more than 5 times press (5-10secs or more) each press.
    Dimitri Zaborski - Yanıt
    Did you learn the answer to your question? I'm having the same issue -- I keep pressing the gold button but the battery light stays on.
    R McP -
    Mi laptop doesn’t turn it on doing that ):
    alexisaguinagam26 - Yanıt
  6. Retina MacBook 2015 Upper Case Assembly Replacement: adım 6, 1 resimden 1.
    • Close the MacBook and carefully flip it upside-down.
  7. Retina MacBook 2015 Upper Case Assembly Replacement: adım 7, 1 resimden 1.
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
    Before the IPD flex cable can be removed the battery disconnect button has be held down for up to 10 seconds. If the LED near the battery connector is switched on it shows that there is power going through the logic board from the battery, once the button is pressed and this light goes off the machine is safe to be worked on.
    Aaron Dalziel - Yanıt
  8. Retina MacBook 2015 Upper Case Assembly Replacement: adım 8, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 8, 2 resimden 2.
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    Only peel back the first half of the tape covering the trackpad cable ZIF connector—do not completely remove.
    Gently - lift tape while wiggling cable side to side. Be sure tape is released, but do not remove completely
    David Nagle - Yanıt
  9. Retina MacBook 2015 Upper Case Assembly Replacement: adım 9, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 9, 2 resimden 2.
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    This is very tricky indeed - at least on my computer. I failed at this point - having skipped to it as sugested above so as not to stress the ribbons on the other side. The ZIF was not as I expected. They had opened when I pulled up the stick cover and I found I was working on the socket itself. The top edge came adrift after almost no pressure being put on it. The ribon did not come free with gentle pulling though. At that point I put the back on again… waited until the battery recharged a bit and found I had not nroken it after all. I doubt I shall try again. It is much harder to replace than the 15 inch - much…
    Simon Anthony - Yanıt
    I’ve just found that I have broken it after all. No keyboard. Bluetooth still works so I can use the machine.
    All in all, an expensive mistake. BTW - I did NOT get the kit from IFIXIT - not sold here.
    I found “Recognizing & Disconnecting Cable Connectors”
    useful, esp. for someone who has not used ZIF connectors and retaining flaps before. There are several retaining flaps that need to be opened. The first time is tricky as you need a sense of how much force to apply. I used the flat end of the provided spudger. Apply progressively firmer upward pressure until the retaining flap pops open. The first time is tricky, but straightforward thereafter.
    Ki Park - Yanıt
    Mouse back and forth between the two right-side thumbnail photos and you will get a little animation feel showing how these ZIF connectors operate—it's very helpful. Apply light but consistent pressure to pop them up. Helps to go side to side if they're a little stubborn.
    this is a great tip Steve!
    Eric - Yanıt
  10. Retina MacBook 2015 Upper Case Assembly Replacement: adım 10, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 10, 2 resimden 2.
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
    it would be nice to have a specific picture of the cable and contacts and how it is oriented in the ZIF connector. This isn't clear in any of these photos or text.
    My trackpad cable snapped so had to replace it and none of the replacement cables have the tape which is on the smaller end to the trackpad. The other end is fairly easy to figure out but the trackpad end isn't as the cable makes a 180 degree turn inside the case (poor design).
    Marc - Yanıt
  11. Retina MacBook 2015 Upper Case Assembly Replacement: adım 11, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 11, 2 resimden 2.
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
    You can open the laptop screen all the way open with it flat in the table (screen facing up) and the keyboard should stay up.
    xavierviveros - Yanıt
  12. Retina MacBook 2015 Upper Case Assembly Replacement: adım 12, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 12, 2 resimden 2.
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
    the moment you opening macbook case and before any tinkering with connections, you MUST press little yellow button on logicboard, located on the right from battery connector - this will disable all power to the board. You can check by looking at the small led on left side of the battery connector - if there is very faint light, it means that power is still there. After pressing button light should go off. Removing screw is not necessary at all, and like I said - you MUST disable power before any touching to connections etc.
    DigiHead - Yanıt
    Where it says
    “2015 models have a silver grounding clip with two foam pads directly under this screw“
    I have a 2015 MacBook & the grounding clip is not there!
    I’m using this guide to investigate why there are lines on screen or darker screen at certain angles of opening it. Also a background ghosting effect on screen too.
    No obvious damage or loose connectors so wondered if the lack of grounding clip can cause these symptoms?
    Anybody out there know?
    nijafe - Yanıt
    Either buy the clip and check, or replace the screen (or LB), but the macbook would more likely not start if there is a missing grounded connection, depending on what is being grounded.
    Sean -
  13. Retina MacBook 2015 Upper Case Assembly Replacement: adım 13, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 13, 2 resimden 2.
    Battery Blocker
    $3.99
    Satın Al
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    I HAD TO DO THIS TWICE. After replacing the battery while following this guide to a 'T', the battery was not being recognized by the logic board. Strangely, with the power unplugged it would still light up the screen and tell me the battery was at a critical level, but it would not boot. Resetting the SMC had no effect. I thought I killed my computer or got a bad battery, so as a last ditch effort I re-opened the case, pressed the battery disconnect button, removed the screw and inserted the battery separation tool again to Physically Disconnect the battery from the mainboard. After about 5 minutes I then removed the tool and reassembled everything, plugged in via 5v iphone charger and USBA-C cable again and LO, the battery is now reporting correctly, charging correctly and allowing me to boot on its power .
    Neil Schultz - Yanıt
  14. Retina MacBook 2015 Upper Case Assembly Replacement: adım 14, 1 resimden 1.
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
    This was oddly the hardest part. That Tri-Point screw just wouldn’t budge! I had to sand the end of the only Tri-point screwdriver I had in the end to get it to fit.
    Stuart - Yanıt
    Be sure to get the metal plate under the chip near where the PT5 screw is before tightening
    abscate - Yanıt
    I should have read the comments before using the provided 1.1 mm Tri-point Y00 bit. I almost stripped the screw but was able to use a small flat head bit to open the screw.
    Ifixit: you may want to update this part in the instructions. Not everyone reads the comment section, esp. when it comes to specification of bits which is basic and must be accurate. This is one of the more critical ones in the procedure that can easily go south. The rest of the instructions are excellent.
    Ki Park - Yanıt
    early 2015 model here. I’ve used a Y1.5 with cautiously applied down force.
    beaudry.ian - Yanıt
    My 2015 had a 2.5mm Y screw not a Y000.
    Michael Bonney - Yanıt
    Adding to the helpful comments above, on replacing the 1.1mm tripoint screw, I found the the magnetism of the nearby speaker coil overcame that of the driver and would draw the screw away or the combo of forces would fling it out of the work area! After fiddling with it for too long, I used some of the battery adhesive removed earlier to attached the screw to the driver. Wax would probably work better if I’d had some.
    jefflyons - Yanıt
    I used the PH00 head to unscrew what they call the “1.1 mm Tri-point Y00 screw”, NOT the Y00 head, and it unscrewed perfectly fine.
    Grace Escamilla - Yanıt
    Agreed, my screw was a PH00.
    stephen delaney - Yanıt
    I have an early 2015 MacBook and it was a PH00 head I needed to use.
    Sean Stein - Yanıt
  15. Retina MacBook 2015 Upper Case Assembly Replacement: adım 15, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 15, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    Emphasis on aligning the bracket correctly. What the pictures do not show is that underneath the flat part of the metal bracket (the area between the two screw holes) is a connector that needs to be accurately aligned. Aligning the two screw holes does not imply that the connector is seated correctly.
    After I re-assembled my 2015 MacBook power would not come on. I thought I had damaged the logic board despite being careful and following instructions. Diagnosing the problem took a while. Retracing the steps and focusing on power supply I was able to determine that the metal flap which hides the connector underneath had not made proper contact.
    What I did was to use a finger to get a tactile feel for the connector underneath the metal bracket aligning properly and then press down vertically when it seemed to be aligned. It’s a subtle tactile feel. After re-doing this step, I got power back. Be careful not to damage the connector as noted in the instructions.
    Ki Park - Yanıt
    Good tip. It’s so easy to damage these fragile connectors by forcing the plug in and reattaching the mounting plate screws
    Peter Newman -
  16. Retina MacBook 2015 Upper Case Assembly Replacement: adım 16, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 16, 2 resimden 2.
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  17. Retina MacBook 2015 Upper Case Assembly Replacement: adım 17, 1 resimden 1.
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
    hey my macbook do not have sound after replacing the topcase, i did connect everything like here you did, also I did the reset of PR and NVRAM. What Can I check more? simply when I open the OS, there is no audio device at all
    dkflu - Yanıt
    The audio jack cable is a bit of a pain to reinsert. I found if I turned the screen and the bottom on its side, like an open book, I had much better orientation and it was much easier to insert.
    Excellent guide and all works like a sharm, but was one issue. After full assemble there wasn't sound. Then I open Macbook again and disconnect and connect audio cable. You must insert cable so, that white stripe will not visible. And sound reveal!
    Pzs Serv - Yanıt
    This helped me, thanks!
    Egbert Kappert -
  18. Retina MacBook 2015 Upper Case Assembly Replacement, Retina MacBook 2015 Lower Case Assembly Removal: adım 18, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement, Retina MacBook 2015 Lower Case Assembly Removal: adım 18, 2 resimden 2.
    • Use tweezers to peel back the tape covering the display cable connector.
  19. Retina MacBook 2015 Upper Case Assembly Replacement: adım 19, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 19, 2 resimden 2.
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
    I'm in trouble, pulling the tape I took off the flap, what can I do?
    Alberto Raso - Yanıt
  20. Retina MacBook 2015 Upper Case Assembly Replacement: adım 20, 1 resimden 1.
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
  21. Retina MacBook 2015 Upper Case Assembly Replacement: adım 21, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 21, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 21, 3 resimden 3.
    iOpener
    $12.99
    Satın Al
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
  22. Retina MacBook 2015 Upper Case Assembly Replacement: adım 22, 1 resimden 1.
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
    A step was skipped. You have to flip up the metal locking tab on the socket before the cable can be removed. See the photo.
    Vin Coniglione - Yanıt
    And be careful when re-inserting the connector. One end of the two indentations got a little bent (I did not notice) which resulted in a black screen when powering up. I used a heat gun (low setting) to separate the cable from the labtop housing. When re-assembling, first insert the connector (after closing the metal flap as instructed), verify that it’s properly seated, then re-attach the rest of the cable to the laptop housing. In the first try, I first re-attached the cable to the housing, then tried to insert the cable connected into the metal socket. Because of a lack of slack, the cable connector at one end got bent slightly. After identifying the problem, I had to straighten it/unbend out using my fingers. Hence it is easier to insert the connector first, then attach the rest of the cable to the laptop housing.
    Ki Park - Yanıt
    Black screen upon reboot:
    Inserting the display ribbon cable into it’s contact without closing the metal flap before reassembly will result in a black screen.
    Charlene Lizut - Yanıt
    I live in a colder climate (and it's winter now) - a hair dryer was absolutely necessary to get this cable loose.
    David Nagle - Yanıt
    OK, when I read those directions, I did it wrong. I followed the instructions and kept the flap closed when the cable was reinserted during reassembly. Of course I got a blank screen. It should read the flap must be closed AFTER the cable is reinserted during reassembly.
    Eric - Yanıt
  23. Retina MacBook 2015 Upper Case Assembly Replacement: adım 23, 1 resimden 1.
    • Separate the upper case assembly from the lower case assembly.
  24. Retina MacBook 2015 Upper Case Assembly Replacement, Audio Jack Board: adım 24, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement, Audio Jack Board: adım 24, 2 resimden 2.
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
    Does unplugging the "dual microphone assembly ribbon cable" affect anything other than the microphones? The headphone jack is separate, for example, right?
    wizfish mcfrabblegabben - Yanıt
    Right. We haven't tested it, but unplugging that cable shouldn't affect anything other than the microphones. You can see the microphone assembly in this guide.
    Jeff Suovanen -
  25. Retina MacBook 2015 Upper Case Assembly Replacement: adım 25, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 25, 2 resimden 2.
    • Use tweezers to pull the microphone assembly ribbon cable free of its connector.
    I broke the microphone assembly ribbon cable, from step twenty five. Is there anyway to fix this, soldering kit, or can I order a new cable online?
    Read Fuller - Yanıt
  26. Retina MacBook 2015 Upper Case Assembly Replacement: adım 26, 1 resimden 1.
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
  27. Retina MacBook 2015 Upper Case Assembly Replacement: adım 27, 1 resimden 1.
    • Remove the audio jack board.
    On your way back during reassembly, as long as you are VERY careful with the ribbon once you do it, it is easier to reattach the ribbon in the connector before reseating the audio jack board.
    lauren - Yanıt
  28. Retina MacBook 2015 Upper Case Assembly Replacement, Dual Microphone Assembly: adım 28, 1 resimden 1.
    • Prepare an iOpener and apply heat to the upper case directly behind the microphone assembly.
    If you are replacing the case upper case check to see if your replacement case has a microphone assembly included. If it does you can skip 28-30
    Marco Romani - Yanıt
  29. Retina MacBook 2015 Upper Case Assembly Replacement: adım 29, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 29, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 29, 3 resimden 3.
    • Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case.
    very difficult to remove, even with heat. Can be purchased on eBay for ~ $10
    zimmerninja - Yanıt
    The upper case sold by iFixit comes with the dual mic
    Tolu Fapohunda - Yanıt
    impossible to remove without damaging the mic. I strongly suggest to remove the screw hodling the keyboard before removing and installing the new mic
    Erick Luna - Yanıt
  30. Retina MacBook 2015 Upper Case Assembly Replacement: adım 30, 1 resimden 1.
    • Remove the dual microphone assembly.
    During reassembly, do you need to apply adhesive to the microphone assembly to glue it back to the case? What adhesive is the best to use?
    Andrei - Yanıt
    Usually with a part like this, the replacement comes with adhesive pre-applied—just peel off the liner and stick it in place. If you’re re-using the old microphone, you might be able to get away with heating it up a little using a heat gun or hair dryer to soften the old adhesive, and then stick it down. Failing that, I’d add a little B7000 adhesive.
    Jeff Suovanen -
    So this was very hard to take off. I probably didn’t allow enough time for the adhesive to heat up and loosen. But I noticed that my new upper case assembly already came with a new dual microphone assembly attached. I’m assuming that all new upper assemplies will come with a microphone preinstalled. If that’s the case this part is not necessary and can be skipped in my opinion.
    Eduardo Chavez - Yanıt
    it is hard to install the new one, but not impossible. I strongly recommend to peel the adhesive and try to insert the dual mic assebly with actual mic holes facing up. Once inside push with some tweezers to final position. Make sure you remove the blck screw holding the keyboard, it will make iy a bit easier
    Erick Luna - Yanıt
  31. Retina MacBook 2015 Upper Case Assembly Replacement, Display Assembly: adım 31, 1 resimden 1.
    • Remove the two 3.3 mm T5 Torx screws securing the display cable assembly.
  32. Retina MacBook 2015 Upper Case Assembly Replacement: adım 32, 1 resimden 1.
    • Remove the single 4.3 mm Phillips #00 screw securing the USB-C port ribbon cable.
  33. Retina MacBook 2015 Upper Case Assembly Replacement: adım 33, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 33, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 33, 3 resimden 3.
    • Unfold the USB-C port ribbon cable until it lays flat, allowing access to the bracket beneath.
    On the 2016 model the USB-C is actually one whole part and can be removed once the display is removed, unfortuanatelly.
    Chavdar Christov - Yanıt
  34. Retina MacBook 2015 Upper Case Assembly Replacement: adım 34, 1 resimden 1.
    • Lift and remove the metal bracket securing the USB-C port ribbon cable connector.
    • During reassembly, be sure the metal tab on the USB-C connector board slides through the slit on the metal bracket.
  35. Retina MacBook 2015 Upper Case Assembly Replacement: adım 35, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 35, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 35, 3 resimden 3.
    • Use a spudger to disconnect the USB-C port ribbon cable by prying the connector straight up.
    • Pry from the side nearest the back edge of the MacBook.
    • Remove the ribbon cable.
  36. Retina MacBook 2015 Upper Case Assembly Replacement: adım 36, 1 resimden 1.
    • Fully open the display.
    • Set the MacBook down on its right edge with the display facing away from you, as shown.
  37. Retina MacBook 2015 Upper Case Assembly Replacement: adım 37, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 37, 2 resimden 2.
    • Remove the four 4.8 mm T8 Torx screws securing the display hinges.
  38. Retina MacBook 2015 Upper Case Assembly Replacement: adım 38, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 38, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 38, 3 resimden 3.
    • Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case.
    • There are only a few millimeters of play between the hinges and the case, so you won't need to push far.
    • Push the upper case forward while pulling back gently on the display.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
    There is a small metal part that falls off once the display cable screws are removed and you try to separate the display from the top cover. Just make sure you put it back correctly.
  39. Retina MacBook 2015 Upper Case Assembly Replacement, USB-C Port: adım 39, 1 resimden 1.
    • Remove the single 2.9 mm T3 Torx screw securing the USB-C port to the upper case.
    this was a 00 philips on my 1.1ghz 2015 gold macbook.
    zimmerninja - Yanıt
    I was going to write the same thing…it is a Phillips screw on my 2015 MacBook.
    Drora Hirsch - Yanıt
  40. Retina MacBook 2015 Upper Case Assembly Replacement: adım 40, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 40, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 40, 3 resimden 3.
    • Slide the USB-C port out of its recess in the upper case, and remove the USB-C port.
    Be careful not to lose the rubber grommet!
    Technical Merritt - Yanıt
    To add to Jon's note about the rubber grommet, alse make sure there is only one rubber grommet if you're using a second hand replacement top assembly.
    Guy Parkin - Yanıt
  41. Retina MacBook 2015 Upper Case Assembly Replacement, Trackpad Assembly: adım 41, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement, Trackpad Assembly: adım 41, 2 resimden 2.
    • Use a pair of tweezers to remove the tape covering the keyboard ribbon cable connector on the trackpad.
  42. Retina MacBook 2015 Upper Case Assembly Replacement: adım 42, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 42, 2 resimden 2.
    • Using a spudger, flip open the retaining flap on the keyboard ribbon cable ZIF connector.
  43. Retina MacBook 2015 Upper Case Assembly Replacement: adım 43, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 43, 2 resimden 2.
    • Gently pull the keyboard ribbon cable out of its slot in the frame.
  44. Retina MacBook 2015 Upper Case Assembly Replacement: adım 44, 1 resimden 1.
    • Remove the five 2.5 mm T3 Torx screws securing the trackpad to the case.
    • Depending on which bit set you use, a T4 driver may fit better. Try both sizes, and use the largest driver that fits fully into the screw head.
  45. Retina MacBook 2015 Upper Case Assembly Replacement: adım 45, 1 resimden 1.
    • Remove the trackpad assembly.
    • Metal brackets on each side of the trackpad may fall away during removal. Be sure to position them as shown in the photo during reassembly.
  46. Retina MacBook 2015 Upper Case Assembly Replacement: adım 46, 2 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 46, 2 resimden 2.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF connector.
  47. Retina MacBook 2015 Upper Case Assembly Replacement: adım 47, 3 resimden 1. Retina MacBook 2015 Upper Case Assembly Replacement: adım 47, 3 resimden 2. Retina MacBook 2015 Upper Case Assembly Replacement: adım 47, 3 resimden 3.
    • Gently peel the keyboard ribbon cable up from the case, and remove the cable.
  48. Retina MacBook 2015 Upper Case Assembly Replacement: adım 48, 1 resimden 1.
    • The upper case remains.
    Great guide!!! Thank you!!! It is not very difficult to replace the keyboard / top cover. However, for some reason the computer didn’t immediately started, I had to reset and connect to power supply and then it started and works fine.
Sonuç
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
20 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
89.898 İtibar
89 adet Kılavuz yazıldı
4 Yorum
please where do i have to put the mushrooms screws? 923-01012
Antonio gaeta - Yanıt
If you look closely at this image in Step 36 you can see them pretty clearly.
Jeff Suovanen -
I changed the keyboard itself; you follow the instructions to step 35 (skipping 29 to 30, microphone removal) and then remove the keyboard ribbon cable connector to the trackpad (step 45). Maybe the most complicated step is ungluing the black backing stuck to the back of the keyboard and then there are almost a hundred tiny screws holding the keyboard to the frame, mostly only an eye strain. Got the keyboard through ebay (spanish keyboard layout).
Lorenzo Segovia - Yanıt
I replaced my keyboard and it won’t turn on.
Patrick Cafferky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 22
Son 30 gün: 78
Her zaman: 26,845
