Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
With the MacBook jumping on the Rose Gold bandwagon, who knows what's lurking inside? Here's the lowdown so far:
12-inch 2304 × 1440 (226 ppi) IPS Retina Display
1.1 GHz dual-core Intel Core m3 processor (configurable up to 1.3 GHz dual-core Intel Core m7)
8 GB of 1866 MHz LPDDR3 RAM
256 or 512 GB PCIe-based flash storage
Intel HD Graphics 515
802.11a/b/g/n/ac Wi-Fi wireless networking and Bluetooth 4.0
Single USB-C port and 3.5 mm headphone jack
If it weren't for the rose gold finish, we'd be hard-pressed to distinguish between this year's Retina MacBook, and the one of yesteryear.
The exteriors look identical, from the Pentalobe screws in the lower case all the way down to the model number—A1534.
Popping the hood on this MacBook gives us an indication that the rose gold beauty is much more than skin deep.
Before delving any deeper into this beauty, we take a quick look at the chips powering the trackpad:
Broadcom BCM5976 touchscreen controller
STMicroelectronics STM32F103 32-bit ARM Cortex-M3 microcontroller
Monolithic Power Systems MP24830HL White LED driver and International Rectifier IRFH3702 power MOSFET
Maxim Integrated MAX11290 analog-to-digital converter (likely)
Macronix MX25L2006EZUI-12G 2 Mb Serial NOR flash memory
Maxim Integrated MAX9028 comparator
Touchpad sensors:
Bosch Sensortec BMA282 accelerometer
Texas Instruments TMP421 temperature sensor
What's that? The pesky tri-wing screw we saw last year grew another, um, wing—now it's a regular ol' repair-friendly Phillips.
Thankfully, all the other internal screws remain standard Phillips and Torx screws.
And at the other end of the MacBook, it seems the USB-C hardware has also changed. The cable is now perma-fixed to the USB board, condensing the two components into a single unit.
...Also, the silicon is new and moved from the cable itself to the USB board. Here's a comparison of the new USB-C hardware (top) with that of the 2015 Retina MacBook (bottom).
Parade Technologies PS8741A (likely an iteration of the PS8740 USB-C redriving switch)
Diodes Incorporated PI1EQX7502 USB 3.0 redriver (likely)
NXP Semiconductor CBTL04043A1 4-Ch. bidirectional crossbar switch
The battery's form factor seems 100% identical to the multi-lobed cell we found in the 2015 Macbook.
And yet somehow, Apple managed to squeeze in a 4% capacity increase from the 7.55 V, 39.71 Wh battery in last year's model. Apple claims this new 7.56 V, 41.41 Wh Li-ion power source should provide up to 11 hours of iTunes movie playback.
Unfortunately, they did not squeeze in any of those nifty adhesive pull tabs we've seen in Apple's iDevices.
Logic Board! What chips is this MacBook serving up?
Intel SR2EN Intel Core m3-6Y30 Processor (4M Cache, up to 2.20 GHz)
Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND Flash (+ 128 GB on the reverse side for a total of 256 GB)
Micron MT41K256M16LY-107:N 512 Mb DDR3L SDRAM memory
Universal Scientific Industrial 339S0250 Wi-Fi module
Broadcom BCM15700A2 (as seen in several other MacBook models) webcam controller (likely)
National Semiconductor 48B1-11 (LP8548B1) backlight driver
Micron EDF4432ACPE-GD-F 4 GB LPDDR3 SDRAM Memory (with SSD controller presumably layered underneath)
But wait, there's even more chips on the back:
Toshiba TH58TFT0DFKLAVF 128 GB MLC NAND flash memory
Samsung K3QF4F40BM-AGCF 4 GB LPDDR3 SDRAM (x2, for a total of 8 GB)
Apple 338S00066 power management IC
Texas Instruments/Stellaris LM4FS1EH SMC controller (replacement codename for TM4EA231)
Microchip (formerly SMSC) EMC1704-2 temperature sensor
Texas Instruments SN650839 step down DC-DC converter (likely), TPS51980A PMIC, and CD3215B01 USB-C controller
Intersil ISL95828 Intel CPU PWM controller
IC identification, continued:
Renesas ISL95530 battery charger
Vishay SiC535 power stage
Maxim Integrated MAX98357B audio amplifier
Texas Instruments TMP102 temperature sensor
Microchip (formerly Atmel) AT93C66B 4 K serial EEPROM memory
Macronix MX25L2006EZUI-12G 2 Mb flash memory
Retina Macbook 2016 Repairability Score: 1 out of 10 (10 is the easiest to repair)
Those pesky tri-wing screws are gone, replaced with lovely standard Phillips screws—but tamper-evident hinge screws make you feel like a hoodlum for repairing your own machine.
The processor, RAM, and flash memory are still soldered to the logic board.
The battery assembly remains entirely, and very solidly, glued into the lower case.
The Retina display is still a fused unit with no separate, protective glass. If the display needs replacing, it'll cost a pretty penny.
50 Yorum
Step 8, Apple 338S00066 should not be the SSD controller. It might be the audio codec.
Step7, The SSD controller should be under the chip "F4432ACPE-GD-F".
It's been reported that the new Apple designed SSD controller sits next to the NAND flash chip instead of under it.
Yes. Apple designed SSD controller is next to the NAND flash chip as Step 7 shown. F4432ACPE-GD-F chip is next to Toshiba NAND Flash chip. SSD controller needs memory. In 2015 model, Apple uses PoP package to put it upon the SSD controller.
Retina MacBook 2015 Teardown Step 14
JJ Wu -
