Ana içeriğe geç
Retro-Bit Retro Duo Cartridge Doors Replacement
Neye ihtiyacın var
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: adım 1, 3 resimden 1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: adım 1, 3 resimden 2. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: adım 1, 3 resimden 3.
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 2, 3 resimden 1. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 2, 3 resimden 2. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 2, 3 resimden 3.
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 3, 3 resimden 1. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 3, 3 resimden 2. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 3, 3 resimden 3.
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 4, 2 resimden 1. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 4, 2 resimden 2.
    • Carefully lift the cartridge door case and set aside.
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 5, 2 resimden 1. Retro-Bit Retro Duo Cartridge Doors Replacement: adım 5, 2 resimden 2.
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
Sonuç
Truong Vo
324 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 881
