Ana içeriğe geç
Retro-Bit Retro Duo Circuit Board Replacement
Neye ihtiyacın var
  1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 2. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: adım 1, 3 resimden 3.
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
    FixBot'a Sor
  2. Retro-Bit Retro Duo Circuit Board Replacement: adım 2, 3 resimden 1. Retro-Bit Retro Duo Circuit Board Replacement: adım 2, 3 resimden 2. Retro-Bit Retro Duo Circuit Board Replacement: adım 2, 3 resimden 3.
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
    FixBot'a Sor
  3. Retro-Bit Retro Duo Circuit Board Replacement: adım 3, 3 resimden 1. Retro-Bit Retro Duo Circuit Board Replacement: adım 3, 3 resimden 2. Retro-Bit Retro Duo Circuit Board Replacement: adım 3, 3 resimden 3.
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
    FixBot'a Sor
  4. Retro-Bit Retro Duo Circuit Board Replacement: adım 4, 3 resimden 1. Retro-Bit Retro Duo Circuit Board Replacement: adım 4, 3 resimden 2. Retro-Bit Retro Duo Circuit Board Replacement: adım 4, 3 resimden 3.
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
    FixBot'a Sor
Sonuç
Truong Vo
324 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G4
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 101
Her zaman: 3,137
