Ana içeriğe geç
Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement
Neye ihtiyacın var
  1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): adım 1, 3 resimden 1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): adım 1, 3 resimden 2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): adım 1, 3 resimden 3.
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After removing the screws, carefully lift the controller casing .
  2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: adım 2, 3 resimden 1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: adım 2, 3 resimden 2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: adım 2, 3 resimden 3.
    • Pinch the top and bottom of the shoulder buttons and lift them out.
    • Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
    • Removing the elastic pads allows easier circuit board access.
  3. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: adım 3, 3 resimden 1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: adım 3, 3 resimden 2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: adım 3, 3 resimden 3.
    • Carefully lift the circuit board from the controller case.
Sonuç
Evelyn
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 54
Her zaman: 1,289
