Ana içeriğe geç
Retro-Bit Retro Duo Controller Button and Pad Replacement.
Neye ihtiyacın var
  1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): adım 1, 3 resimden 1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): adım 1, 3 resimden 2. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): adım 1, 3 resimden 3.
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After screw removal, carefully lift the controller casing.
  2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 2, 3 resimden 1. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 2, 3 resimden 2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 2, 3 resimden 3.
    • Pinch the top and bottom of the shoulder pads, then lift out.
    • There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
  3. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 3, 3 resimden 1. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 3, 3 resimden 2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 3, 3 resimden 3.
    • Carefully lift the circuit board from the controller case.
  4. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 4, 3 resimden 1. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 4, 3 resimden 2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 4, 3 resimden 3.
    • To replace the action button pad, lift this part out.
    • Lift the Select and Start button pad.
    • If replacing the D-Pad, lift this pad.
    • Pinch and lift the shoulder button pads.
  5. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 5, 3 resimden 1. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 5, 3 resimden 2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: adım 5, 3 resimden 3.
    • Support the controller face and push buttons toward the inner case.
    • Use care. The buttons have a tiny tab to keep them in place.
    • Support the controller face and push the D-Pad toward the inner case.
Sonuç
Evelyn
223 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,169
