Ana içeriğe geç
Retroid Pocket 3 Button Pad Replacement
Neye ihtiyacın var
  1. Retroid Pocket 3 Button Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 Button Pad Replacement: adım 2, 3 resimden 1. Retroid Pocket 3 Button Pad Replacement: adım 2, 3 resimden 2. Retroid Pocket 3 Button Pad Replacement: adım 2, 3 resimden 3.
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 Button Pad Replacement: adım 3, 2 resimden 1. Retroid Pocket 3 Button Pad Replacement: adım 3, 2 resimden 2.
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 Button Pad Replacement: adım 4, 3 resimden 1. Retroid Pocket 3 Button Pad Replacement: adım 4, 3 resimden 2. Retroid Pocket 3 Button Pad Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
  5. Retroid Pocket 3 Button Pad Replacement, Button Pad: adım 5, 3 resimden 1. Retroid Pocket 3 Button Pad Replacement, Button Pad: adım 5, 3 resimden 2. Retroid Pocket 3 Button Pad Replacement, Button Pad: adım 5, 3 resimden 3.
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
  6. Retroid Pocket 3 Button Pad Replacement: adım 6, 2 resimden 1. Retroid Pocket 3 Button Pad Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    • Carefully lift the board out of the device.
  7. Retroid Pocket 3 Button Pad Replacement: adım 7, 2 resimden 1. Retroid Pocket 3 Button Pad Replacement: adım 7, 2 resimden 2.
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
  8. Retroid Pocket 3 Button Pad Replacement: adım 8, 1 resimden 1.
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
  9. Retroid Pocket 3 Button Pad Replacement: adım 9, 3 resimden 1. Retroid Pocket 3 Button Pad Replacement: adım 9, 3 resimden 2. Retroid Pocket 3 Button Pad Replacement: adım 9, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
  10. Retroid Pocket 3 Button Pad Replacement: adım 10, 3 resimden 1. Retroid Pocket 3 Button Pad Replacement: adım 10, 3 resimden 2. Retroid Pocket 3 Button Pad Replacement: adım 10, 3 resimden 3.
    • Carefully pry up the silicone button pad with a Spudger tool.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 897
