Ana içeriğe geç
Retroid Pocket 3 LCD Screen Replacement
Neye ihtiyacın var
  1. Retroid Pocket 3 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    FixBot'a Sor
    Yorum Ekle
  2. Retroid Pocket 3 LCD Screen Replacement: adım 2, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 2, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Retroid Pocket 3 LCD Screen Replacement: adım 3, 2 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    FixBot'a Sor
    Yorum Ekle
  4. Retroid Pocket 3 LCD Screen Replacement: adım 4, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 4, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Retroid Pocket 3 LCD Screen Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    FixBot'a Sor
    Yorum Ekle
  6. Retroid Pocket 3 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    FixBot'a Sor
    Yorum Ekle
  7. Retroid Pocket 3 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Unclip and remove the one ribbon cable on the left.
    FixBot'a Sor
    Yorum Ekle
  8. Retroid Pocket 3 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    FixBot'a Sor
    Yorum Ekle
  9. Retroid Pocket 3 LCD Screen Replacement: adım 9, 2 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    FixBot'a Sor
    Yorum Ekle
  10. Retroid Pocket 3 LCD Screen Replacement: adım 10, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 10, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement: adım 10, 3 resimden 3.
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    FixBot'a Sor
    Yorum Ekle
  11. Retroid Pocket 3 LCD Screen Replacement, Button Pad: adım 11, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement, Button Pad: adım 11, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement, Button Pad: adım 11, 3 resimden 3.
    • Undo the ribbon cable clips using the Spudger tool.
    • Unclip the cable on the left side of the board.
    • Carefully lift the ribbon cable to the right to remove it from the clip.
    FixBot'a Sor
    Yorum Ekle
  12. Retroid Pocket 3 LCD Screen Replacement: adım 12, 2 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 12, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 5.9 mm screws from the controller board.
    FixBot'a Sor
    Yorum Ekle
  13. Retroid Pocket 3 LCD Screen Replacement: adım 13, 2 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 13, 2 resimden 2.
    • Using the Spudger tool, put the tip under the edge of the rubber button pad to start lifting it.
    • Button pad will loosen and lift straight out of the casing.
    FixBot'a Sor
    Yorum Ekle
  14. Retroid Pocket 3 LCD Screen Replacement: adım 14, 1 resimden 1.
    • Move to the right side of the device.
    • Using a spudger, undo the ribbon cable clip connected to the main PCB along with the joystick ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  15. Retroid Pocket 3 LCD Screen Replacement: adım 15, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 15, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement: adım 15, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 5.9 mm screws.
    FixBot'a Sor
    Yorum Ekle
  16. Retroid Pocket 3 LCD Screen Replacement: adım 16, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 16, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement: adım 16, 3 resimden 3.
    • Carefully pry up the silicone button pad with a Spudger tool.
    FixBot'a Sor
    Yorum Ekle
  17. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: adım 17, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: adım 17, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement, Trigger Button: adım 17, 3 resimden 3.
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    FixBot'a Sor
    Yorum Ekle
  18. Retroid Pocket 3 LCD Screen Replacement: adım 18, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 18, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement: adım 18, 3 resimden 3.
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    FixBot'a Sor
    Yorum Ekle
  19. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: adım 19, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: adım 19, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement, LCD Screen: adım 19, 3 resimden 3.
    • Using the Spudger tool, remove the two speakers at the bottom of the device by gently prying them out.
    • Speakers are held by double-sided tape.
    FixBot'a Sor
    Yorum Ekle
  20. Retroid Pocket 3 LCD Screen Replacement: adım 20, 3 resimden 1. Retroid Pocket 3 LCD Screen Replacement: adım 20, 3 resimden 2. Retroid Pocket 3 LCD Screen Replacement: adım 20, 3 resimden 3.
    • Remove the joysticks by unscrewing the two 3.5mm screws with a Phillips #00 screwdriver.
    • Remove the metal backplate from the front casing of the device by unscrewing the ten 3.5mm screws using the Phillips #00 screwdriver.
    • Carefully lift the ribbon cable from the metal backplate
    FixBot'a Sor
    Yorum Ekle
Sonuç
Troy
85 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Hello. Can you tell where I can find a new replacement screen?
Aliaksandr - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 105
Her zaman: 2,456
