Ana içeriğe geç
Retroid Pocket 3 Motherboard Replacement
Neye ihtiyacın var
  1. Retroid Pocket 3 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    FixBot'a Sor
    Yorum Ekle
  2. Retroid Pocket 3 Motherboard Replacement: adım 2, 3 resimden 1. Retroid Pocket 3 Motherboard Replacement: adım 2, 3 resimden 2. Retroid Pocket 3 Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Retroid Pocket 3 Motherboard Replacement: adım 3, 2 resimden 1. Retroid Pocket 3 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    FixBot'a Sor
    Yorum Ekle
  4. Retroid Pocket 3 Motherboard Replacement: adım 4, 3 resimden 1. Retroid Pocket 3 Motherboard Replacement: adım 4, 3 resimden 2. Retroid Pocket 3 Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Retroid Pocket 3 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the three 4.5 mm screws with a Phillips #00 screwdriver on the main board.
    FixBot'a Sor
    Yorum Ekle
  6. Retroid Pocket 3 Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a spudger, put the tip under the aerial connecter and rotate upwards to unclip the plug.
    FixBot'a Sor
    Yorum Ekle
  7. Retroid Pocket 3 Motherboard Replacement: adım 7, 1 resimden 1.
    • Unclip and remove the one ribbon cable on the left.
    FixBot'a Sor
    Yorum Ekle
  8. Retroid Pocket 3 Motherboard Replacement: adım 8, 1 resimden 1.
    • Use a spudger to unclip and remove the two ribbon cables on the right side.
    FixBot'a Sor
    Yorum Ekle
  9. Retroid Pocket 3 Motherboard Replacement: adım 9, 2 resimden 1. Retroid Pocket 3 Motherboard Replacement: adım 9, 2 resimden 2.
    • Use a spudger to disconnect the two speaker cables on the bottom of the board.
    FixBot'a Sor
    Yorum Ekle
  10. Retroid Pocket 3 Motherboard Replacement: adım 10, 3 resimden 1. Retroid Pocket 3 Motherboard Replacement: adım 10, 3 resimden 2. Retroid Pocket 3 Motherboard Replacement: adım 10, 3 resimden 3.
    • Start lifting the board to give you access to the vibration motor on the metal case.
    • Use a spudger to carefully pry the motor free; it is bound with double-sided tape.
    • Carefully lift the board out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 51
Her zaman: 1,483
