Ana içeriğe geç
Retroid Pocket 3 Trigger Button Replacement
Neye ihtiyacın var
  1. Retroid Pocket 3 Trigger Button Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    FixBot'a Sor
    Yorum Ekle
  2. Retroid Pocket 3 Trigger Button Replacement: adım 2, 3 resimden 1. Retroid Pocket 3 Trigger Button Replacement: adım 2, 3 resimden 2. Retroid Pocket 3 Trigger Button Replacement: adım 2, 3 resimden 3.
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Retroid Pocket 3 Trigger Button Replacement: adım 3, 2 resimden 1. Retroid Pocket 3 Trigger Button Replacement: adım 3, 2 resimden 2.
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    FixBot'a Sor
    Yorum Ekle
  4. Retroid Pocket 3 Trigger Button Replacement: adım 4, 3 resimden 1. Retroid Pocket 3 Trigger Button Replacement: adım 4, 3 resimden 2. Retroid Pocket 3 Trigger Button Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: adım 5, 3 resimden 1. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: adım 5, 3 resimden 2. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: adım 5, 3 resimden 3.
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    FixBot'a Sor
    Yorum Ekle
  6. Retroid Pocket 3 Trigger Button Replacement: adım 6, 3 resimden 1. Retroid Pocket 3 Trigger Button Replacement: adım 6, 3 resimden 2. Retroid Pocket 3 Trigger Button Replacement: adım 6, 3 resimden 3.
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 21
Son 30 gün: 90
Her zaman: 1,601
