Ana içeriğe geç
Retroid Pocket Flip D-Pad Replacement
Neye ihtiyacın var
  1. Retroid Pocket Flip D-Pad Replacement, Back Plate Assembly: adım 1, 2 resimden 1. Retroid Pocket Flip D-Pad Replacement, Back Plate Assembly: adım 1, 2 resimden 2.
    • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
    • Use a plastic opening pick to carefully separate the back cover from the device.
    FixBot'a Sor
    Yorum Ekle
  2. Retroid Pocket Flip D-Pad Replacement: adım 2, 2 resimden 1. Retroid Pocket Flip D-Pad Replacement: adım 2, 2 resimden 2.
    • Use a plastic spudger to carefully lift and disconnect the battery connector.
    • Use tweezers to disconnect the connector from its socket.
    FixBot'a Sor
    Yorum Ekle
  3. Retroid Pocket Flip D-Pad Replacement, Joystick: adım 3, 2 resimden 1. Retroid Pocket Flip D-Pad Replacement, Joystick: adım 3, 2 resimden 2.
    • Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
    • Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
    • Use tweezers to remove the "R" sticker to reveal the last screw.
    FixBot'a Sor
    Yorum Ekle
  4. Retroid Pocket Flip D-Pad Replacement: adım 4, 3 resimden 1. Retroid Pocket Flip D-Pad Replacement: adım 4, 3 resimden 2. Retroid Pocket Flip D-Pad Replacement: adım 4, 3 resimden 3.
    • Carefully lift and unstick the fan module using a plastic spudger, then remove it.
    • Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
    • Use a plastic spudger to carefully separate the shield from the board.
    • Do not pull abruptly: the shield is partially bonded to the CPU with thermal paste. You can use a hair dryer on low heat to soften the paste slightly before lifting the shield.
    FixBot'a Sor
    Yorum Ekle
  5. Retroid Pocket Flip D-Pad Replacement: adım 5, 3 resimden 1. Retroid Pocket Flip D-Pad Replacement: adım 5, 3 resimden 2. Retroid Pocket Flip D-Pad Replacement: adım 5, 3 resimden 3.
    • Use tweezers to unclip and remove the two ribbon cables on each joystick module.
    • Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
    FixBot'a Sor
    Yorum Ekle
  6. Retroid Pocket Flip D-Pad Replacement, Motherboard: adım 6, 3 resimden 1. Retroid Pocket Flip D-Pad Replacement, Motherboard: adım 6, 3 resimden 2. Retroid Pocket Flip D-Pad Replacement, Motherboard: adım 6, 3 resimden 3.
    • Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
    • Use tweezers to disconnect the ribbon cables from the board.
    • Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
    • Always lift the coaxial connector straight up. Do not pry at an angle, as this can detach the socket from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Retroid Pocket Flip D-Pad Replacement: adım 7, 2 resimden 1. Retroid Pocket Flip D-Pad Replacement: adım 7, 2 resimden 2.
    • Remove the six 5.8 mm screws from the motherboard using a JIS #00 screwdriver.
    • Carefully lift the motherboard out of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Retroid Pocket Flip D-Pad Replacement, D-Pad: adım 8, 3 resimden 1. Retroid Pocket Flip D-Pad Replacement, D-Pad: adım 8, 3 resimden 2. Retroid Pocket Flip D-Pad Replacement, D-Pad: adım 8, 3 resimden 3.
    • Remove the rubber piece backing the D-pad out of the device.
    • Lift the D-pad out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 114
